Message 1 of 2
Intermittent issues - HomeHub5 - Ping timeouts
Hi,
for a long time I've experienced an unreliable connection. When working the connection is fast (around 50mb/s) but when there's issues it's terrible. I've called BT support and they sent a BT engineer who tested the line and found it to be very good. He tested it extensively so I'm confident the line to the property is good.
When experience poor browsing (on all devices in the house... wired and wireless) a ping test confirms timeouts...
64 bytes from 216.58.210.35: icmp_seq=668 ttl=51 time=16.792 ms
64 bytes from 216.58.210.35: icmp_seq=669 ttl=51 time=753.675 ms
64 bytes from 216.58.210.35: icmp_seq=670 ttl=51 time=14.526 ms
64 bytes from 216.58.210.35: icmp_seq=671 ttl=51 time=15.353 ms
<snipped>
64 bytes from 216.58.210.35: icmp_seq=678 ttl=51 time=68.198 ms
64 bytes from 216.58.210.35: icmp_seq=679 ttl=51 time=18.199 ms
64 bytes from 216.58.210.35: icmp_seq=680 ttl=51 time=197.508 ms
64 bytes from 216.58.210.35: icmp_seq=681 ttl=51 time=14.883 ms
Request timeout for icmp_seq 683
64 bytes from 216.58.210.35: icmp_seq=684 ttl=51 time=14.141 ms
64 bytes from 216.58.210.35: icmp_seq=685 ttl=51 time=13.878 ms
64 bytes from 216.58.210.35: icmp_seq=686 ttl=51 time=13.923 ms
Request timeout for icmp_seq 687
64 bytes from 216.58.210.35: icmp_seq=688 ttl=51 time=22.678 ms
64 bytes from 216.58.210.35: icmp_seq=689 ttl=51 time=32.006 ms
Request timeout for icmp_seq 690
Request timeout for icmp_seq 691
Request timeout for icmp_seq 692
Request timeout for icmp_seq 693
64 bytes from 216.58.210.35: icmp_seq=690 ttl=51 time=4074.204 ms
Request timeout for icmp_seq 695
Request timeout for icmp_seq 696
<snipped>
Request timeout for icmp_seq 717
ping: sendto: No route to host
Request timeout for icmp_seq 718
<snipped>
Request timeout for icmp_seq 736
Request timeout for icmp_seq 737
Request timeout for icmp_seq 738
Request timeout for icmp_seq 739
Request timeout for icmp_seq 740
64 bytes from 216.58.210.35: icmp_seq=741 ttl=51 time=14.727 ms
Request timeout for icmp_seq 742
64 bytes from 216.58.210.35: icmp_seq=742 ttl=51 time=1837.320 ms
64 bytes from 216.58.210.35: icmp_seq=744 ttl=51 time=13.427 ms
64 bytes from 216.58.210.35: icmp_seq=745 ttl=51 time=16.301 ms
64 bytes from 216.58.210.35: icmp_seq=746 ttl=51 time=14.165 ms
Request timeout for icmp_seq 747
64 bytes from 216.58.210.35: icmp_seq=747 ttl=51 time=1007.145 ms
64 bytes from 216.58.210.35: icmp_seq=749 ttl=51 time=16.657 ms
64 bytes from 216.58.210.35: icmp_seq=750 ttl=51 time=14.702 ms
64 bytes from 216.58.210.35: icmp_seq=751 ttl=51 time=14.721 ms
^C
--- www.google.co.uk ping statistics ---
752 packets transmitted, 683 packets received, 9.2% packet loss
round-trip min/avg/max/stddev = 12.526/78.335/4074.204/294.699 ms
Powering my homehub off and on seems to fix the issue for a while. The issue often occurs every few minutes and typically lasts for a couple of minutes.
BT support have already got me to reset back to factory defaults. I've got a homehub5 and most of the equipment has been checked by the engineer. The equipment I think there's still doubt around in the hub.
BTW I'm not using 5Ghz and the issue persists with a wired connection so that really rules out issues with the wireless functionality.
Any ideas would be most welcome as I'm about to go with another ISP as the issue is driving everyone to distraction!
Thanks,
John
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Intermittent issues - HomeHub5 - Ping timeouts
Hi John,
I'll be able to take a look at your connection. Please can you send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
