balaks
Message 1 of 11
Intermittent loss of broadband connection
When playing online games my home hub randomly appears to lose connection and the yellow light comes on - after a couple of minutes it seems to sort itself out and the light turns blue again and I regain connection. It appears to be quite random but over the last couple of weeks the regularity of this has increased a lot and is making gaming virtually impossible.
Any ideas what could be causing this?
10 REPLIES 10
CJT80
Recognised Expert
Message 2 of 11
Re: Intermittent loss of broadband connection
@balaks
There could be a number of reasons, but to try and help:
  • What Hub are you using?
  • What socket is the hub plugged into?
  • Is it using any phone extension leads?
  • Any other sockets in the house?
  • Have you tried a phone in the socket to see if there is any "noise"? - Dial 17070 option 2.
Let us know and we can see what we can do to help.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
balaks
Message 3 of 11
Thanks for the response:
  • What Hub are you using? - Home Hub 5 - Type B
  • What socket is the hub plugged into?- The main telephone socket in the house
  • Is it using any phone extension leads? - No
  • Any other sockets in the house? - No
  • Have you tried a phone in the socket to see if there is any "noise"? - Dial 17070 option 2. - Dont own a landline phone but I might get a cheap one to check this.
imjolly
Message 4 of 11
can you post stats from hub - troubleshooting then helpdesk
have you tried using test socketwith a filter which is behind bottom half of master
you really need to check your line with a corded phone as it could save you the call out fee of £129.99 just for a £5 investment in a cheap corded phone
balaks
Message 5 of 11
Hi -
   1. Product Name: HomeHub5
2.Serial number: +076286+1505008125
3.Firmware version: v0.07.06.01239-BT (Type B) Last updated 3/3/2017
4. Board version: 01
5. ADSL uptime: 0 days, 13:27:46
6. Bandwidth: 1191 / 11831
7. Data sent/received: 46.1 MB / 1.3 GB
8. Broadband username: bthomehub@btbroadband.com
9. BT Wi-fi: Yes
10. 2.4GHz wireless network/SSID: BTHub5-HQ5H
11. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4GHz wireless security: WPA2 Only (Recommended)
13. 2.4GHz wireless channel: 11
14. 5GHz wireless network/SSID: BTHub5-HQ5H 5GHz
15. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
16. 5GHz wireless security: WPA2 Only (Recommended)
17. 5GHz wireless channel: 44
18. Firewall: Default
19. MAC Address: 4c:09:d4:b3:de:6d
20. VPI/VCI: 0/38
21. Modulation: G.992.5(ADSL2+)
22. Latency type: Fast
23. Software variant: -
24. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
I bought a corded phone and did the quiet line thing - I didn't hear any crackling or interference at all.
imjolly
Message 6 of 11
are you connected to test socket with a filter?  if so did you check other sockets for dial tone?
balaks
Message 7 of 11
If the filter is the little white box that the modem gets connected to which then goes into the socket then yes it was connected with a filter. I had been using the normal socket but have now unscrewed the front plate of the socket and have connected the filter to what I assume is the test socket.
imjolly
Message 8 of 11
If now in test socket can you repost router stats please. Extension sockets 'dead'
balaks
Message 9 of 11
2. Serial number: +076286+1505008125
3. Firmware version: v0.07.06.01239-BT (Type B) Last updated 3/3/2017
5. ADSL uptime: 0 days, 00:48:42
6. Bandwidth: 1203 / 12311
7. Data sent/received: 5.6 MB / 110.8 MB
9. BT Wi-fi: Yes
20. VPI/VCI: 0/38
imjolly
Message 10 of 11
Test socket has given you a bit more speed both up and down   Just hope now stable as in test socket
