Message 1 of 3
Intermittently unable to connect to HKC alarm system
I have recently had HKC alarm system installed, and have HKC SecureComm app installed on iPone and iPad.
Most of the time I am unable to connect to the system, but sometimes I connect OK, and can successfully control the alarm system
My alarm installer informed me that this a common problem with connection via BT Home Hub  (I have Home Hub 6)
Rounter Event log shows following on unsuccessful connection:
18:16:31, 26 Dec.
BR_LAN:The DHCP options that are offered by the device (id:171): DiscoverOptions: 53,55,57,61,51,12 | DiscoverOption55: 1,121,3,6,15,114,119,252 | RequestOptions: 53,55,57,61,50,54,12 | RequestOption55: 1,121,3,6,15,114,119,252 | HostName: iPad-3 | VendorId:
18:16:31, 26 Dec.
:DHCP Confirmation of Request
Any ideas how to resolve this issue?
2 REPLIES 2
Message 2 of 3
Re: Intermittently unable to connect to HKC alarm system
@Daveiw100
You might be better off using a third party router, its likely to give you a lot less trouble than the HH6.
This one is very popular, and works with all BT services.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/archer-vr400/v2/
If you only want 2.4GHz then there is a cheaper option, about £35.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/td-w9970/
They are both very easy to configure.
Message 3 of 3
Been doing some further investigation.......
BT HomeHub Event log always shows successful connection from polling every few minutes.......
12:53:49, 02 Jan.
eth2:[Device Connected] MAC Address:70:B3:D5:F1:F7:7D Host Name: IP Address: 192.168.0.245, lease duration is 86400 seconds.
12:53:49, 02 Jan.
BR_LAN:The DHCP options that are offered by the device (id:174): DiscoverOptions: 53,61,51,55 | DiscoverOption55: 1,3,6 | RequestOptions: 53,61,54,50,51,55 | RequestOption55: 1,3,6 | HostName: | VendorId:
12:53:49, 02 Jan.
eth2:DHCP Lease issued 192.168.0.245 to 70:B3:D5:F1:F7:7D
12:53:49, 02 Jan.
So why cannot I not always successfully ping the device?
Most of the time,  I get response "Destination Host unreachable", or "Timed Out".  Sometimtes I can successfully ping the device
