Message 1 of 3
Internal fibre cable
The cable with red ends which came with BT Smart Hub2, which goes between new internal fibre socket and WAN on the hub is not long enough to allow me to place the hub where I want. What cable would I need to replace the short one.
2 REPLIES 2
Message 2 of 3
Re: Internal fibre cable
 CAT5e cable will do. The colour of the cable and ends are meaningless. An ethernet cable doesn't know what colour it is. It doesn't need to.
Message 3 of 3
Thanks for that it's appreciated. ☺
