Repuran
Message 1 of 25
Internet Disconnects but Light Stays Blue
For the alst 4-5 weeks I've had countless calls with BT and changed filters, powercycled the router and changed the socket it's in multiple times. During the evening hours between 5-10pm usually my connection constantly drops but the light remains blue on my Home Hub 4 ADSL connection.
BT think the problem is with a device inside my house intefering with the signal/frequency as the light stays blue and it reconnects within 30 seconds everytime. The devices used between these hours are usually the Landline phone, a Windows vista Laptop, 2 iPhones and an iPad.
Does anyone have experience with an issue like this and have any thing I can do?
24 REPLIES 24
Message 2 of 25
Re: Internet Disconnects but Light Stays Blue
are you using a wired or wireless connection
Repuran
Message 3 of 25
Well I have tried putting the hub in the master socket and unplugging everything else with a wireless connection and the problem still persisted. Usually I have the Desktop connected via wire and it still disconnectes frequently.
Message 4 of 25
try downloading insidder and run the programme this should enable you to select a clear wireless channel
Repuran
Message 5 of 25
I'll try chancging the channel (currently on 11 am changing to 6) but I have no neghbours so I don't think it could be an overused channel, if I move the hub to another socket in my house and use a wired connection to the desktop it still disconnects so surely this eliminates the wireless issues?
Message 6 of 25
which port are you using for the ethernet connection have you tried using a different port
Repuran
Message 7 of 25
I'll give that a try now but I don' think it's that as when it drops all devices lose connection even the wireless ones.
Message 8 of 25
it could be a faulty hub but all options have to be checked out first
Repuran
Message 9 of 25
Yeah, I think I've tried everything the only options left is a specific device inside my house causing it or the hub itself, BT said they will send a new BT home hub 4 tomorrow so if it still persisits after that arrives I'll let you know.
Thanks.
Message 10 of 25
post back if you need further help
