Repuran
Message 11 of 25
Re: Internet Disconnects but Light Stays Blue
New hub arrived at 8am this morning which I was very impressed by and I set it up shortly after, connection has been stable until now, it has disconnected twice in last hour but is this to be expected when adding a new hub or should I contact BT again?
Message 12 of 25
are you connected to test socket?
is it the hub dropping internet connection or you dropping the wifi conenction to the hub?
run btspeedtester and when first test completes run the diagnostic test and post results
Repuran
Message 13 of 25
ATM my hub isn't connected to the main socket as otherwise the desktops cannot have a wired connection, but the main socket still ha s a filter in anyway. The first time the hub changed to orange but only disconnected for about 5-10 seconds, the second time all devices lost connection (both wired and wireless) but the light remained blue, connection was lost for 5-10 minutes but some pages would load incredibly slowly (slower than other peoples usage would cause it to go). Running tests atm.
Message 14 of 25
You really need to connect to the test socket to eliminate any possible internal wiring problems
Repuran
Message 15 of 25
I have the old casing where there is no test socket inside, the problem is still happening frequently tonight (light staying blue but connection timing out pretty often on both wired and wireless devices), what's the next step I should take?
Message 16 of 25
Are you connected to master socket if you have no test socket. As you cannot connect to the test socket you cannot eliminate internal wiring as causing the problem
Repuran
Message 17 of 25
Yeah I've had the hub connected to the master socket where it enters the house and on another socket downstairs and connection still timed out at random intervals.
Message 18 of 25
It looks as if you need an engineer visit
Repuran
Message 19 of 25
Yeah, BT aren't very willing to send one even though I offered to pay. A friend earlier said the phone like I was talking on was very unstable with a lot of background noise from it , which could be linked to the disconnections?
Message 20 of 25
line noise will be the cause of your broadband problem you really need to report it as a voice fault with no mention of broadband in the call
