Message 11 of 20
Re: Internet Dropping Issue
Thank you Keith, I will definitely try this on a day when we do not have internet because as of right now, I have a lot to do online before it goes off again.
Thank you for all of your help. I will try and report back.
Message 12 of 20
can you try using the test socket with a filter to see if that helps your stability and maybe your connection speed.  the front of your master just unclips ( no screws) and test socket is visible so just connect filter
if you are able to use test socket can you repost your hub stats please
Message 13 of 20
@eme172 wrote:
Thank you for your input.
We live in the Highlands and Islands, so it's fairly standard but I will admit the times I spoke to BT about switching from fibre, the reaction I got on the phone was as if I had asked them for a miracle. I will definitely look into other companies if this continues because thus far, it's been a total mess, not to mention a waste of my time and money, minus my income. Much appreciated, thanks.
@eme172 You would be very lucky to find an ADSL connection, unless another company has installed equipment in the BT exchange, which seems unlikely, based on your location, as they are probably trying to close the exchanges.
Personally, I would suspect the master socket as being the cause of the long disconnections, as its been reported many times before.
Just today, causing speed loss.
https://community.bt.com/t5/BT-Fibre-broadband/Please-help-broadband-speed-lowered-by-50/td-p/213653...
Message 14 of 20
You may find that even someone walking past the socket, or even a temperature change, is causing the connection to go off. Its probably affecting your connection speed as well, so I would check it as soon as you are able.
If you could please update this thread with the results, it would be helpful.
Message 15 of 20
Hi there,
  • We had internet for two days (Sun-Monday night).
  • I had a lot to do online so I made use of it while it lasted.
  • This morning (Tues) woke up to no internet.
  • This morning at 7:30am I put the filter directly into the test socket as indicated.
  • 12pm ish we just got internet, this does not usually happen. If it's off in the morning it generally does not come on until late afternoon if at all.
  • Posting hub stats below from now.
Product code:Smart Hub 2
Serial number:+091298+2036018197
Firmware version:v0.24.04.11017-BT
Firmware updated:Wed Jan 6 16:49:52 2021
Board version:R01
GUI version:1.71 05_06_2020
DSL uptime:0 days,00 Hours12 Mins58 Secs
Data rate:800 Kbps / 3.399 Mbps
Maximum data rate:1.167 Mbps / 9.698 Mbps
Noise margin:15.5 / 18.4
Line attenuation:15.2 / 36.3
Signal attenuation:15.2 / 39.6
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:8.0 MB Uploaded  / 84.7 MB Downloaded
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-Z5AKJK
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-Z5AKJK
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:E4:75:DC:19:CF:14
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 16 of 20
@eme172
Well if it stays connected, you could eventually get a faster connection, but the fact that it did not come up right away, would indicate a problem with your line, which needs to be sorted.
Message 17 of 20
Ok - I will pass that info along. Thank you very much. Will post updates.
Message 18 of 20
@eme172
Is your problem now resolved?
Message 19 of 20
We found out that everyone in our immediate area has the same issue with BT connectivity, so it's not at all isolated to our home. The perks of living rurally. Something we have to live with for now.
Thank you for your help.
Message 20 of 20
Hi @eme172 ,
It won't help you solve you problem but I have to say it is a pleasure to see your pictures posted at a reasonable size instead of having to use a magnifying  - well done you !!
