Hi everyone,
thought I'd join the forum since i've been having speed problems for a while now.
Recently internet pages, youtube videos and just about anything has been taking ages to load.
Did a speed test and this was my result:
Connection speed 8.13Mb
I've restarted my hub also and that hasn't helped.
Any advice would be much appreciated! 🙂
Also
Download speedachieved during the test was - 1.97 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
download speed
1.97 Mbps
upload speed :0.36
ping latency: 18.75
just repost your hub stats when you get 3+ days connection time and then mods will help
I've had 3+ days connection time.
you need to post to show 3+ days connection time and if you have just reset the hub then you need to wait until you get 3 days again
Ok, I made this post last Thursday and now it is Monday. So i've waited 4 days since restarting the hub and here's my results.
Download Speed : 1.99
Upload Speed: 0.36
Ping : 27.50
Download speed For your connection, the acceptable range of speeds Additional Information: Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 2 Mbp |
Please help because the internet is becoming painfully slow...
Connection Information
ADSL Settings
stats looking good just need to wait on mod offering help
