TehDoubleJ
Message 21 of 36
Re: Internet Speed and Stability Issues
Can't recall anything like that. Sadly I don't have a spare filter, only other thing that I can think of is peak demand causing problems
Speed appears to have increased slighty but its still a bit sluggish
Speedtester.bt.com is still giving me this error
'The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.'
Message 22 of 36
you often get that message when it is busy - just keep trying or wait to a quieter time tomorrow
Message 23 of 36
also other electrical items can develop faults particularly small power supplies for mobile phones and similar as per the link posted by imjolly
TehDoubleJ
Message 24 of 36
After needing the phone line last night I put the socket back together and pluged the phones back and the internet ran fine till about 9PM again I was unable to even load the speedtester.bt.com. It eventually sped up at around 11pm. came back home today to find the internet slow again but was able to get the speedtester to work. Here are the results.
 Download speedachieved during the test was - 0.03 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 12.65 Mbps
Upload speed achieved during the test was - 0.99Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Here is the home hub stats. looking at the connection time it appears to have maintained its connection since I reattached the phone lines. was hoping to leave it in the test socket for longer times but was unable to.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 23:51:37
Downstream:14 Mbps
Upstream:1.204 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.5 dB / 5.4 dB
Line attenuation (Down/Up):27.8 dB / 18.2 dB
Output power (Down/Up):19.1 dBm / 12.4 dBm
FEC Events (Down/Up):20830566 / 1163
CRC Events (Down/Up):644281 / 169
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):797140 / 280
Error Seconds (Local/Remote):35240 / 67
Message 25 of 36
hi can you reconnect to the test socket again please using a filter then you can connect a phone as well as your hub and post back the results
Message 26 of 36
can you run btspeedtester again please and post the results as the last set showed a very low download speed
TehDoubleJ
Message 27 of 36
Reattached to the test socket. I am unable todo another test using speedtester.bt.com due to having done one so soon. I have used Speedtest.net instead http://www.speedtest.net/result/1939064201.png
here is the Hub stats
ADSL Line Status
Connection time:0 days, 00:06:53
Downstream:14 Mbps
Upstream:1.177 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.7 dB / 6.2 dB
Line attenuation (Down/Up):27.9 dB / 18.2 dB
Output power (Down/Up):19.0 dBm / 12.4 dBm
FEC Events (Down/Up):818 / 0
CRC Events (Down/Up):2 / 0
HEC Events (Down/Up):1 / 0
Error Seconds (Local/Remote):38175 / 69
Message 28 of 36
try the brtspeedtester but use beta lite version
the speeedtest.net link does not work for me
TehDoubleJ
Message 29 of 36
Yes im Sorry I messed up the linking in any case appears I have let enough time expire. here is a new speedtester.bt.com
Download speedachieved during the test was - 11.21 Mbps
Upload speed achieved during the test was - 0.97Mbps
Message 30 of 36
at this time that looks a very good connection
