TehDoubleJ
Message 11 of 36
Re: Internet Speed and Stability Issues
Hello. Its been roughly the same amount of time when the original stats were posted and there is clearly a big difference in errors. The internet has been stable and at correct speeds since connected however it has been stable and fast before. so Im still unable to verify if its internal wiring or external. I guess the only way is to attempt this when it goes bad again which can has been random and at no fixed times.
here is the home hub stats
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 02:40:12
Downstream:14 Mbps
Upstream:1.184 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):7.3 dB / 6.0 dB
Line attenuation (Down/Up):27.9 dB / 18.2 dB
Output power (Down/Up):19.1 dBm / 12.4 dBm
FEC Events (Down/Up):671289 / 0
CRC Events (Down/Up):19128 / 1
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):11205 / 1
Error Seconds (Local/Remote):
1490 / 1
Message 12 of 36
suggest you leave it in the test socket until you have the next problem then repost hubstats and a speedtest
Message 13 of 36
connecting to the test socket has really helped and has dropped the amount of crc/hec errors which suggests there is a prolem with your internal wiring.  just leave it for another day and post another set of stats to see if still connected and also the amount of errors.
TehDoubleJ
Message 14 of 36
My apologies I intended to post a speedtest but I forgot to. So here is the speedtest while the internet is good.
I will attempt to leave it attached to the test socket as long as possible also.
 Download speedachieved during the test was - 10.69 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 12.65 Mbps
Upload speed achieved during the test was - 0.95Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Message 15 of 36
looks goodSmiley Wink
Message 16 of 36
looking good 🙂
TehDoubleJ
Message 17 of 36
Hello. Appears my internet is having issues again Speed has slowed considerably I tried to run the speedtester.bt.com and it returned an error. (Will post the results if I can)
Nothing Has changed since the last post No phones or extensions connected Hub still attached to the test socket.
Hub Stats
ADSL Line Status
Connection time:0 days, 07:09:17
Downstream:14 Mbps
Upstream:1.184 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):6.4 dB / 5.8 dB
FEC Events (Down/Up):8394214 / 0
CRC Events (Down/Up):259749 / 1
HEC Events (Down/Up):356304 / 1
9529 / 1
Message 18 of 36
the crc/hec errors have significantly increase since your last stats post
19000 crc in 2hr 40 then 839000 after 7hrs  suggesting there is interference causing the errors - anything close to router that could cause a problem http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
TehDoubleJ
Message 19 of 36
The hub is elevated up away from everything sat ontop of a cabinet, and has not changed its position since it was first installed(about a year ago now). I am unable to see anything suddenly causing issues but stranger things have no doubt happened.
Can filters suddenly go bad? we had a powercut/surge a few months ago is it possible the filter was damaged?
Also noticing the time it could be hitting peak demand right now which could explain the sudden issues?
Message 20 of 36
filters even without any power surge can stop working correctly - never know until your internet starts having problems often calls disconnecting the broadband
