Message 31 of 36
Re: Internet Speed and Stability Issues
looks a lot better now need to try more spread over the day - you can use the beta version which you can run anytime as you are only looking for download speed and not profile
TehDoubleJ
Message 32 of 36
I suspected it would start working again as soon as the hub reconnected to the network. A hub restart usally fixed the problem before(restarting often gets old very quickly and I believe can upset the IP profile too?)
Message 33 of 36
you are on the new profile system and restarts won't make any difference to the profile as it will change as and when the conenction speed changes - no delay like adslmax
TehDoubleJ
Message 34 of 36
Almost the same time as yesterday the internet has slowed to a crawl. However, the hub is still attached to the Test socket and has not changed since yesterdays post.
Speedtester.bt.com took a while but it finally worked
Download speedachieved during the test was - 0.06 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 12.65 Mbps
Upload speed achieved during the test was - 0.91Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Also here is the Speedtest beta
Download Speed (Mbps): 0.24
Upload Speed (Mbps): 0.96
Ping Latency(ms) 36.88
ADSL Line Status
Connection Information
Line state:Connected
Connection time:1 days, 00:20:27
Downstream:14 Mbps
Upstream:1.177 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.5 dB / 5.9 dB
Line attenuation (Down/Up):27.9 dB / 18.2 dB
Output power (Down/Up):19.0 dBm / 12.4 dBm
FEC Events (Down/Up):32884112 / 0
CRC Events (Down/Up):832448 / 56
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1307375 / 57
Error Seconds (Local/Remote):66217 / 76
Message 35 of 36
if you are in the test socket then as not peak time I would expect to see a good download speed not the very low figure you have.  I would contact the mods and get their help
contact mods
can take up to 3/5 working days for mods to contact you
check your exchange in case there are problems showing
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
Message 36 of 36
i agree with imjolly you need mods assistance
