DannyR2811
Message 1 of 3
Internet Super Slow
It's been terrible the last few days. ADSL line status Connection information Line state Connected Connection time 0 days, 6:44:30 Downstream 6,654 Kbps Upstream 1,272 Kbps ADSL settings VPI/VCI 0/38 Type PPPoA Modulation ITU-T G.992.5 Latency type Interleaved Noise margin (Down/Up) 5.8 dB / 5.3 dB Line attenuation (Down/Up) 35.0 dB / 20.5 dB Output power (Down/Up) 0.0 dBm / 12.8 dBm Loss of Framing (Local) 0 Loss of Signal (Local) 0 Loss of Power (Local) 0 FEC Errors (Down/Up) 95131 / 0 CRC Errors (Down/Up) 0 / N/A HEC Errors (Down/Up) N/A / 0 Error Seconds (Local) 0 How can i get my output power up?
2 REPLIES 2
Message 2 of 3
Re: Internet Super Slow
your power settings are a known reporting bug
Message 3 of 3
Hi Welcome to the forums
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
