dave70
Message 1 of 15
Internet connection keeps dropping
Hi
We have a HH 3.  The pc is wired to the hub.  The printer is wired to the hub.  The laptop is wireless.
We are constantly loosing our internet connection on the pc in internet explorer and chrome.  we also loose the emails in live mail.  When the internet is down we are unable to print.  All the lghts stay on on the hub.  The hub has been recently replaced by BT, but the situation is still the same.
Tonight I had the laptop working at the same time as the pc.  The pc had no internet connection, but the laptop did!
Can anyone shed any light on this please.  It has dropped several times when making secure payments leaving us not knowing if the transaction has been completed.  Also interesting that when email doesn't work, desktop help offers to fix the problem, but always hangs looking for the email acoounts.
Any help would be greatly appreciated
Dave
14 REPLIES 14
Message 2 of 15
Re: Internet connection keeps dropping
welcome to the forum
can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester http://speedtester.bt.com and post the results.
are you connected to the NTE5 master or test socket or somewhere else? Do you have any phone extension sockets in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone
Someone may then be able to offer help/assistance/suggestions to your problem
Distinguished Guru
Message 3 of 15
@dave70 wrote:snip
Have you tried updating the Ethernet driver on the PC?
-+-No longer a forum member-+-
dave70
Message 4 of 15
I didn't know there was a driver associated with this.  Where do I need to look to find out what it is?
Sorry to be so denseSmiley Happy
dave70
Message 5 of 15
Connection Information
Line state:
Connected
Connection time:
1 days, 16:59:01
Downstream:
4.617 Mbps
Upstream:
1.039 Mbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Fast
Noise margin (Down/Up):
13.4 dB / 5.7 dB
Line attenuation (Down/Up):
41.7 dB / 23.8 dB
Output power (Down/Up):
19.5 dBm / 12.6 dBm
FEC Events (Down/Up):
0 / 0
CRC Events (Down/Up):
573 / 337
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
HEC Events (Down/Up):
1237 / 193
Error Seconds (Local/Remote):
1714 / 5801
 This shows a continuous connection, but in trying to do this, every time I loaded a new page I had to keep refreshing, or it would say page not available.
Have tried in all the different sockets - care of BT trying to sort the problem, replaced filters, plugged in at main socket etc.
Have tried the quiet line test - and it is quiet - assume that is the right answer?
Thanks for your help
Message 6 of 15
if you get windows to check for updates it should find any updates for your network card along with any other updates required.
your noise margin is a bit high at 13 as normal about 6 but if you are connected to the test socket then I would just leave it 24/7 and your noise margin should reduce with an increase in your speed.
Distinguished Guru
Message 7 of 15
It's suggested that you go direct to the manufacturers website and download them from there.
But, you can try it this way...
Click start and type device manager
(it'll probably show after only typing dev)
Click on it
new window opens
Look down the list for Network adapters
click the + and it should show all the current devices installed
Look for something like PCI-E Fast Ethernet and right click
Select Update Driver Software - windows will then check online for you
dave70
Message 8 of 15
not currently in the test socket - so move to it?
And repeat?
Message 9 of 15
your best connection will be in the test socket
Distinguished Guru
Message 10 of 15
My fellow rapid response technician has answered the aboveSmiley Very Happy
Did it find and install an updated driver?
