DaveNI1979
Expert
Message 1 of 19
Internet connection keeps dropping
18 REPLIES 18
DaveNI1979
Expert
Message 2 of 19
Re: Internet connection keeps dropping
line dropped again as I was trying figure out how to copy line stats from the hub to this page? anyone know? I could do it before but seems not be recognised now.
Message 3 of 19
are you using IE9?  if so need to use compability mode.  otherwise should work
DaveNI1979
Expert
Message 4 of 19
ok, i switched to chrome, hopefully it works now.
ADSL line status<script type="text/javascript"></script>
Connection information<script type="text/javascript"></script>
Line stateConnected
Connection time0 days, 14:37:31
Downstream1,856 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.7 dB / 11.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)16.8 dBm / 12.3 dBm
Internet connection configuration
Connection time0 days, 0:10:18
Data transmitted/received (MB)11.36 / 419.09
Broadband user namebthomehub@btbroadband.com
Password********
TCP/IP settings<script type="text/javascript"></script>
Broadband network IP address
Default gateway
Primary DNS194.72.9.42
Secondary DNS194.74.65.69
As you can see my adsl stays on but still losing connection to the internet. I tried resetting the hub yest but no luck its doing same today.
edit:- heres the speedtester results which is normal for me
Download speedachieved during the test was - 1391 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :1856 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 1500 Kbps
Message 5 of 19
can you got back to the adsl stas and post the errors you may have to 'show detail' at the bottom.
strange it shows your internet has been connected for 14hrs.  your noise margin is normal and with an attenuation of 63.5 at least you are on a very long line from the exchange.
are you connected to the master or test socket or somewhre else?
DaveNI1979
Expert
Message 6 of 19
ADSL line status
Line stateConnected
Connection time0 days, 15:10:06
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)6.8 dB / 11.0 dB
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)30985 / 43
CRC Errors (Down/Up)477 / 2147480000
HEC Errors (Down/Up)nil / 33
Error Seconds (Local)179
  Hide Details
I know its very weird, Its like im losing connection but still connected to the exchange somehow. Ive about 4miles from the exchange so on a very long line but stable at 1.5mb for ages now but just this random disconnects from pc and ps3s. I did just now try a different wireless channel, from 11 to 9. See if thats it. Im connected directly to the master socket btw and pc is connected by ethernet and ps3s are wireless. Heres the full stats thanks for your time.
Message 7 of 19
for the wireless you can try downloading inssider2 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
do you have any extension sockets in your home?  if so have you tried the test socket?  your noise margin does not suggest any reset problems and you have the correct profile for yout speed
DaveNI1979
Expert
Message 8 of 19
k, ill do that and let you know if thats the problem.
DaveNI1979
Expert
Message 9 of 19
doesnt seem to work on my pc inSSIDer, it says no wi-fi interfaces found. would this be because my pc has no wifi on it? I just use the wifi for phones and ps3s
Message 10 of 19
yes sorry my fault - I should pay more attention
if you have extension sockets have you tried the test socket?
have you tried the quiet line test  dail 17070 option 2  should hear nothing and best done with corded phone if possible
