wswxw06
Message 1 of 5
Internet connection lost when I/C call received
Over the last few months or so I have noticed that everytime I get an incoming call on my landline my internet connection goes down. I then have to disconnect my internet access and then reconnect. If that does not work I have to restart my home hub.
I have the BT Hub Phone 2.1 with an additional VOIP line. I have checked Hub Manager but all looks ok.
Any suggestions ?
4 REPLIES 4
john46
Message 2 of 5
Re: Internet connection lost when I/C call received
you have a high resistance joint you need to report the fault to BT Faults on 151
Devon_Dave
Distinguished Guru
Message 3 of 5
It can also be caused by a faulty ADSL filter. Have you tried plugging the router direct into the test point of your main socket? Then make a test call to your home number.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
wswxw06
Message 4 of 5
Phoned 151 and they have discovered fault on line between exchange and house. They are currently checking it out
john46
Message 5 of 5
Ok please keep us posted on progress
