zcosmin
Message 1 of 4
Internet connection problems
I am having some connection problems, my internet does not work, but it says that im connected but the internet does not work, but if i change my ip address with a program my internet works ? :S Please someone help asap, maybe im getting DDosed?
ASAP, thanks
3 REPLIES 3
Message 2 of 4
Re: Internet connection problems
hi you must be connected to the internet to have made this post your problem is not very clear and what programme are you using to change your ip address?
could you please try and explain more clearly the problem
zcosmin
Message 3 of 4
forget the bit that says i am connected, ok, so when i go on my computer the internet will not work, but if i change my ip address with a program called hotspot shield the internet works fine, but if i close the program and restore back to my normal ip the internet will not work :s
zcosmin
Message 4 of 4
and i have also upgraded to bt infinity2 76mb/s,today i got it
