Jonny1
Message 1 of 5
Internet constantly disconnecting
Over the course of the past week I have experienced the BT internet I have been provided is consatntly disconnecting every 2-15minutes. The connection never lasts - when disconnected the WIFI is still connected on my laptop, the lights on the hub are still blue.
The connection is terrible, constanly disconnecting especially when 1 or more people are using the internet. Does anyone have any advice?
22:08:44, 28 Jul.( 1292.240000) Admin login successful by 192.168.1.108 on HTTP
22:08:28, 28 Jul.( 1276.230000) New GUI session from IP 192.168.1.108
22:08:21, 28 Jul.( 1269.870000) Lease for IP 192.168.1.108 renewed by host LAPTOP-RTF6TD2S (MAC 84:ef:18:77:8d:5f). Lease duration: 1440 min
22:08:21, 28 Jul.( 1269.870000) Device connected: Hostname: LAPTOP-RTF6TD2S IP: 192.168.1.108 MAC: 84:ef:18:77:8d:5f Lease time: 1440 min. Link rate: 52.0 Mbps
22:08:21, 28 Jul.( 1269.850000) Lease requested
22:08:21, 28 Jul.ath0: STA 84:ef:18:77:8d:5f IEEE 802.11: Client associated
22:08:20, 28 Jul.( 1268.910000) Lease for IP 192.168.1.64 renewed by host EME-414738 (MAC fc:c2:de:41:47:38). Lease duration: 1440 min
22:08:20, 28 Jul.( 1268.910000) Device connected: Hostname: EME-414738 IP: 192.168.1.64 MAC: fc:c2:de:41:47:38 Lease time: 1440 min. Link rate: 20.2 Mbps
22:08:20, 28 Jul.( 1268.890000) Lease requested
22:08:18, 28 Jul.ath0: STA fc:c2:de:41:47:38 IEEE 802.11: Client associated
22:08:18, 28 Jul.ath0: STA fc:c2:de:41:47:38 IEEE 802.11: Client disassociated
22:08:17, 28 Jul.ath0: STA 84:ef:18:77:8d:5f IEEE 802.11: Client disassociated
22:08:14, 28 Jul.( 1262.690000) Lease for IP 192.168.1.69 renewed by host android-cfde55225189e0d1 (MAC d8:50:e6:2e:19:3a). Lease duration: 1440 min
22:08:14, 28 Jul.( 1262.690000) Device connected: Hostname: android-cfde55225189e0d1 IP: 192.168.1.69 MAC: d8:50:e6:2e:19:3a Lease time: 1440 min. Link rate: 39.0 Mbps
22:08:14, 28 Jul.( 1262.650000) Lease requested
22:08:12, 28 Jul.ath0: STA d8:50:e6:2e:19:3a IEEE 802.11: Client associated
22:08:11, 28 Jul.ath0: STA d8:50:e6:2e:19:3a IEEE 802.11: Client disassociated
4 REPLIES 4
Webby
Message 2 of 5
Re: Internet constantly disconnecting
That seems to be a wireless devices dropping and requesting a new IP address lease from the hub.
Try one factory reset of the hub, reconnect the wireless devices one at a time and see how you get on.
Jonny1
Message 3 of 5
Thanks for the reply Webby,
Tried what you suggested, reset the hub and remove the devices. After 10 mins the connection dropped again, then 2minutes later.
Any other suggestions?
Webby
Message 4 of 5
The factory reset using a pin in the pinhole should remove all devices anyway. You shouldn't need to do them manually.
john46
Message 5 of 5
try increasing the lease time to 21 days that may help
