Expert
Message 51 of 70
Re: Internet disconnects but no resync occurs?
i don't agree with you imjolly and john that its the snr thats causing the ppp to drop. it has to be something to do on the backhaul network side or in that remit, not with the physical connection on the copper legacy network. if the CRC's were so high then it would drop the physical connection not just the ppp session, and dlm wouldn't have lowered the snr margin to 3dB again if it didn't think the line could hold it. so i still say that it should be further investigated by the bt wholesale diagnostics team.
Message 52 of 70
Mind you the connection time here says 9 hours
Connection information
Connection time: 0 day, 09:03:57
Data transmitted/received (GB): 0.043 / 1.434
Broadband username: bthomehub@btbroadband.com
Password: Not configured
TCP/IP settings
Broadband network IP address: 86.176.129.0
Default gateway: 217.32.141.35
Primary DNS: 213.120.234.2
Secondary DNS: 194.72.0.114
___________________________
Message 53 of 70
I think you are right Astar27 , to me that sounds more correct as the connection to the exchange is not the part that is dropping its the PPP session. like you said.
Message 54 of 70
it's certainly another possibilty to be considered.
I would wait and see how your current connection gets on and if it stays stable
the dlm does reset back to 3db even when people have had problems and had reset to 6db - maybe theory says it shouldn't but practice says it does
Message 55 of 70
I will wait a day or two and see how the connection goes, and If it does still drop I think it needs to be looked at by the bt wholesale diagnostics team like Astar27 says.
Message 56 of 70
@imjolly wrote:
it's certainly another possibility to be considered.
I totally agree with you on that IMJ there are many posts  that that the DLM resets to 3dB and the only way to stop it is  as has been seen to  have the SNR fixed to 6dB rather then a simple reset  as  I remember Keith commenting  on the SNR being Fixed to solve the problem
Expert
Message 57 of 70
There is no reason why a line should be restricted of its full potential when the ppp issue is such a simple one to fix.
Message 58 of 70
I'm not convinced you are correct but would be a good solution if you are rather than a higher noise margin - just need to wait and see
Expert
Message 59 of 70
Its probably a misconfigured port that gets overloaded and because it's not configured properly it has to drop the session
Message 60 of 70
Okay the problem just happened about an hour ago, I was out at the time but the stats show that it did. the adsl stats are still showing a high connention time though while the Internet  connection infomation only says about an hour and a half.
Line state:Connected
Connection time:1 day, 05:18:40
Downstream:23,960 Kbps
Upstream:1,195 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):3.1 dB / 6.7 dB
Line attenuation (Down/Up):7.5 dB / 5.0 dB
Output power (Down/Up):0.0 dBm / 11.2 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):140 / 121
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):1141 / 110
Error Seconds (Local/Remote):0 / 105
Connection time:0 day, 01:40:04
Data transmitted/received (GB):0.002 / 0.178
Broadband username:bthomehub@btbroadband.com
Password:Not configured
TCP/IP settings
Broadband network IP address:109.156.233.122
Default gateway:217.32.141.35
Primary DNS:213.120.234.2
Secondary DNS:194.72.0.114
If I look in the event long PPP is coming up a lot.
  21:00:21,10 July.DHCP Lease issued for IP 192.168.1.73 to host (MAC 00:23:12:0D:73:54), duration: 1 day
  21:00:21,10 July.Receive a DHCP request: 192.168.1.73, 00:23:12:0D:73:54.
  19:37:24,10 July.CWMP:session completed successfully
  19:37:22,10 July.CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 4 VALUE CHANGE
  19:37:20,10 July.WAN Auto-sensing detected port DSL
  19:37:20,10 July.WAN Auto-sensing last connection port: DSL
  19:37:14,10 July.WAN connection WAN3_TR069_INTERNET_R_ATM1_0_38 connected.
  19:37:14,10 July.PPP IPCP Receive Configuration ACK
  19:37:14,10 July.PPP IPCP Send Configuration Request
  19:37:14,10 July.PPP IPCP Receive Configuration Reject
  19:37:14,10 July.PPP IPCP Receive Configuration NAK
  19:37:14,10 July.PPP IPCP Send Configuration ACK
  19:37:14,10 July.PPP IPCP Receive Configuration Request
  19:37:14,10 July.PPP CHAP receive success: authentication ok
  19:37:14,10 July.PPP CHAP Receive Challenge
  19:37:14,10 July.PPP LCP Receive Configuration ACK
  19:37:14,10 July.PPP LCP Send Configuration Request
  19:37:14,10 July.PPP LCP Receive Configuration Reject
  19:37:14,10 July.PPP LCP Send Configuration ACK
  19:37:14,10 July.PPP LCP Receive Configuration Request
  19:37:13,10 July.PPP LCP Send Configuration Request
  19:37:09,10 July.PPP LCP Send Termination Request
  19:37:08,10 July.OpenWiFi tunnel down
  19:37:06,10 July.WAN connection WAN3_TR069_INTERNET_R_ATM1_0_38 disconnected.[ERROR_ISP_TIME_OUT]
  19:37:06,10 July.PPP LCP Send Termination Request
  19:30:30,10 July.Possible PS or DA. src=193.192.113.234 DST=86.176.129.0 LEN=40 TOS=0x00 PREC=0x00 TTL=106 ID=256 PROTO=TCP SPT=6000 DPT=3389 WINDOW=16384 RES=0x00 SYN URGP=0
