Message 1 of 9
Internet dropping out wired and wireless
I'm on infinity 1,  after around 5 to 6pm the internet drops right out wired and wireless.
The light stays blue on the home hub 5 but no internet whatsoever, only a reboot puts it right.
Any clues ?
1. Product Name: HomeHub5
2. Serial number: +076286+1520013534
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 9/12/2015
4. Board version: 01
5. VDSL uptime: 0 days, 02:45:54
6. Data Rate: 9995 / 38560
7. Maximum Data Rate: 12847 / 52020
8. Noise Margin: 6.4 / 6.3
9. Line Attenuation: 28.4 / 21.6
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 31.4 MB / 251.6 MB
12. Broadband username: bthomehub@btbroadband.com
8 REPLIES 8
Recognised Expert
Message 2 of 9
Re: Internet dropping out wired and wireless
Presumably this is a regular occurrence and it's not only happened once or twice?
From what you posted the VDSL uptime shows 2hrs 45mins. Was that captured just after a reboot and hence the short connection time?
When the "internet drop" occurs does the line state under Advanced -> Broadband -> Connection still show as connected? Is there anything in the logs at the time of the problem? You can see these from Troubleshooting -> Event Log and then filter on WAN.
Regards
Message 3 of 9
Regards
Not looked if it is still showing as connected but I will.  The connection had dropped this morning when I was up for work at 2am, I only noticed as I was checking my email on my phone just before I left the house, so I rebooted the hub and it was fine.
Can't see any problems in the event log.  Not sure what I should be looking for.
Recognised Expert
Message 4 of 9
Not sure what the logs will show either, but if you can get them just after the connection drop issue you're seeing and post them back here, we can take a look.
Regards
Message 5 of 9
Regards
Next time it drops out I will take a look.
Cheers..
Message 6 of 9
smf22.  One thing that has occured to me is, a few weeks ago my upload speed increased from around 32mbps to 45mbps.  I think that might of triggered the unstability causing the dropouts. It is now back to 30-32mbps and not had any drops for a couple of days..
Message 7 of 9
Upload on Infinity 1 is capped to 10meg.
Message 8 of 9
Sorry, meant download..
The connection stats have changed . The data rate has dropped
5. VDSL uptime: 1 days, 09:36:00
6. Data Rate: 9995 / 32400
7. Maximum Data Rate: 13291 / 51986
8. Noise Margin: 6.7 / 10.4
11. Data sent/received: 165.6 MB / 1.2 GB
Message 9 of 9
Your line is now in a banded profile with a max connection speed of 32400kbps.
