Newbie
Message 1 of 3
Internet speed the same despite getting BT Infinity and fibre-optic...
Hello,
   I had btinfinity and fibreoptic installed a couple months ago and it doesnt seem to have made any different to my internet speed, in fact if anything it is slower! Is there anything I can do to test it or make sure that settings are at optimal level etc...?
2 REPLIES 2
Message 2 of 3
Re: Internet speed the same despite getting BT Infinity and fibre-optic...
Use this speed tester. Once you have done the speed test do the diagnostic test then post all the results including IP profile up and down back here.
http://speedtest.btwholesale.com/
Message 3 of 3
Are you using a wireless connection to the hub?  You should really use a hard wired ethernet connection while performing any speed tests, as wifi will probably limit the performance.
