imjolly
Message 21 of 37
Re: Intervleaving PLEASE switch it off
is there line noise which is causing a problem  try quiet line test  dial 17070 option 2  should be quiet and bets with a corded phone  if cordless then dull hum normal
what estimares do you get if you enter your phone number https://www.btwholesale.com/includes/adsl/main.html
James_lol
Message 22 of 37
i did a quite test and im not sure if a little noise if normal its a corded phone to the filter, it sounds almost as if air or gas is leaking through it to give you some idea?
ADSL MaxUp to 5.5--4.5 to 6.5Available
Fixed Rate2 ----
Available
imjolly
Message 23 of 37
if you are connected to test socket with filter and try quiet line test with corded phone I would expect silence apart from the announcement
James_lol
Message 24 of 37
i was connected to the test socket (unscrewed from faceplate) i have issues with my internal wiring which is another problem for another day
thank you
imjolly
Message 25 of 37
have you removed the bellwire from terminal 3 in all sockets?
bellwire removal
imjolly
Message 26 of 37
looking at the stats you posted your connection speed is better than the estimate and will get even better probably full 8mb when you get noise margin down to 6db
James_lol
Message 27 of 37
OK, i took a photo (It's a mess) i seem to have more wires than in that guide. But back to the noise on my phone line is there anything that can be done?
thanks
http://s556.photobucket.com/user/bruzer_dog/media/bt.gif.html
john46
Message 28 of 37
If the noise is still at the test socket have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can then it needs reporting to BT faults on 151 with no mention of broadband in the call
James_lol
Message 29 of 37
I will Report it now, i have little faith in the tech team since they alsmost push me to the side when i mention interleaving to them its all about download speeds which i have little use for
thank you
James_lol
Message 30 of 37
they did a line test and found no faults
