Newbie
Message 1 of 5
Ip profile lower than actual speed
Hi, so I'm new to infinity (3day past install) and I've got anything from 0.6mb/s download to 168mb//s (wifi on ipad) however my ip profile shows as 43mb/s it's currently averaging as 60-70 should I expect this to drop because of the ip profile,FB9249C0-5D79-437E-BA2B-B9BD6139CD17.PNG
4 REPLIES 4
Sage
Message 2 of 5
Re: Ip profile lower than actual speed
There would appear to be a problem with the speedtest.
Which Infinity package are you on FTTC or FTTP?
Did you test with a wired connection? If not could you do so and post the results.
Newbie
Message 3 of 5
this is just one from the last three days all above the ip profile, i dont have anthing that i could do a wired test with at the moment but ill borrow something in the next few days to test that.
its a fttc connection and all the speed test excede the what the cabinet says
and its the infinity 2 im on
Sage
Message 4 of 5
The maximum on Infinity 2 is 80Mbps so it's an impossible figure the speedtest is giving you.
This is most likely due to using a wireless connection to conduct the test.
Newbie
Message 5 of 5
thanks for that, ill try and get a wired test to find out whays really happening
