Message 11 of 40
Re: Ip profile
ok thankyou
Message 12 of 40
Re: Ip profile
There is always someone around to help when you post back
Message 13 of 40
Re: Ip profile
hi my adsl setting now saying nearly 5 days i have been on phone to bt for the 10th time and still my speed is very poor and my ip profile still not changed i really would like to no who to turn to now many regards sheila
Recognised Expert
Message 14 of 40
Re: Ip profile
Post your current stats and the BTW speedtest results - the one after more detail which provides the IP profile. Hopefully one of the gurus will explain things or a mod will post here.
Message 15 of 40
Re: Ip profile
As already said you now need to post your adsl stats showing the connection time and also run btspeedtester and when first test completes run diagnostic test and post the results
Message 16 of 40
Re: Ip profile
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.37 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.37 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:5 days, 00:07:01
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):10.6 dB / 21.0 dB
Line attenuation (Down/Up):17.8 dB / 10.0 dB
Output power (Down/Up):19.8 dBm / 11.9 dBm
FEC Events (Down/Up):0 / 41943
CRC Events (Down/Up):9107289 / 49484
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):23123919 / 13508
Error Seconds (Local/Remote):494069 / 72579
Message 17 of 40
Re: Ip profile
the mods should reply to you when they read your post
Message 18 of 40
Re: Ip profile
You have a very high number of errors for your connection time - do you find problems loading pages at night? You may be better with interleaved rather than fast
Moderator
Moderator
Message 19 of 40
Re: Ip profile
Hi Shelajoe,
I should be able to get your profile back up to where it should be. Please can you send me in your details using the link found in the "About Me" section of my profile?
PaddyB
Message 20 of 40
Re: Ip profile
yes day time is abit better but not by much to be honest
