musicman1967
Message 1 of 13
Ip profile
Hi,
I need to reset my ip profile because by mistake my router was turned on and off a few times so my ip profile is set to low. How can i rest it?
thanks
12 REPLIES 12
john46
Message 2 of 13
Re: Ip profile
all you need to do is maintain a stable connection for 3/5 days and your IP profile will increase automatically
musicman1967
Message 3 of 13
Re: Ip profile
Yes I have been connected for 5 days and 7 hours and still no increase
 IP Profile for your line is - 3.39 Mbps
usually I get over 4MP and sometoimes 5MP
Can someone please rest it now since the system has not. Thanks
ax. DSLAM throughputkBit/s4064448
Min. DSLAM throughputkBit/s3584448
Attainable throughputkBit/s4680884
Current throughputkBit/s3840448
Latency 8 ms8 ms
Bit swap off
imjolly
Message 4 of 13
Re: Ip profile
can you post router stats with internet connection time shown not just system conenction time which is different
run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
john46
Message 5 of 13
Re: Ip profile
can you please post the noise margin figures and connection times from your router as the router up time and connection times can be different
musicman1967
Message 6 of 13
Re: Ip profile
Best Effort Test: -provides background information.
 Download  Speed
 3.32 Mbps
0 Mbps4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 3.32 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
2. Upstream Test: -provides background information.
 Upload Speed
 0.33 Mbps
0 Mbps0.45 Mbps
Upload speed achieved during the test was - 0.33Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
musicman1967
Message 7 of 13
Re: Ip profile
Latency 8 ms8 ms
Bit swap offon
Signal-to-noise ratiodB1315
Line attenuationdB5232
Power cutbackdB00
  Loss of
Signal Loss of
Frame Forward Error Correction Cyclic Redun-
dancy Check No Cell Delineation Header Error Control
CPE0066922237425400
COE681665042061
musicman1967
Message 8 of 13
Re: Ip profile
FRITZ!BoxConnectionDSL Exchange
448 kBit/s
3840 kBit/s
DSL version
1.35.63.10
DSL enabled
[5 day(s)10:31:07]
ADSL (ITU G.992.1) Annex A
Broadcom
2.0 - H1 0
john46
Message 9 of 13
Re: Ip profile
your lower IP Profile is  due to the increased noise margin once that reduces then your IP Profile will increase
musicman1967
Message 10 of 13
Re: Ip profile
i thought you said it would  incresed after 3 to 5 days of stable connection?
How can I lower the noise margin?
