velvetsoup
Message 1 of 2
Iplayer stutters so much with BT YouView+ Box
I have bt fibre and BT YouView+ Box. Quite often the iplayer stutters a fair bit, but works fine through Mac Pro using Ethernet . Does the BT YouView+ Box self update? What can I do to get this too work seem less ?
thanks
lister
1 REPLY 1
rarmitage124
Recognised Expert
Message 2 of 2
Re: Iplayer stutters so much with BT YouView+ Box
What type of youview box is it.
To check for updates:
Press the YouView button on your BT remote.
Select Settings.
Select Device Management.
Select Software Update.
Select Get Update.
To update players:
Do exactly the same thing but select player update. I think its called.
Hope this helps 🙂
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
