borderline
Message 1 of 7
Ipod Touch
I cannot connect to BTopenzone or btFon.
I type username and password (i'm sure they are ok) and i keep going back again and again to the login page.
I don't know what to do, i tried everything, this does not work:  http://bt.custhelp.com/cgi-bin/bt.cfg/php/enduser/cci/bt_adp.php?p_sid=uQVN32Lj&cat_lvl1=346&cat_lvl...
6 REPLIES 6
Raid1968
Message 2 of 7
Re: Ipod Touch
Posted Sunday and no Mods have replied yet hmmmm
Possibly an issue with the hotspot, where you at an official hotspot i.e Starbucks, Cafe Nero ect...or private residence, make sure your login details are correct.
Contact Openzone - 0800 022 3322 option 4, 3
borderline
Message 3 of 7
Re: Ipod Touch
I tried at starbucks, macdonalds, at the airport and not even at home thru the hub. Nothing works
Moderator
Moderator
Message 4 of 7
Re: Ipod Touch
Hi Borderline
Have you checked the status of your BT Fon account.
Try the link below to see if the account is active.
https://www.bt.com/wifi/secure/index.do?s_cid=con_FURL_btfon
Cheers
Stuart
crick
Newbie
Message 5 of 7
Re: Ipod Touch
Hello,
I have the exact same issue. I have checked my BT Fon status and it is active.
Wifi works perfectly fine when I am at home but not when I am in an Openzone area.
Can anyone help?
Camille.
Stormbringer
Message 6 of 7
Re: Ipod Touch
had a similar problem and i opted back in to fon ( even tho it said i was on fon) and next day it worked
borderline
Message 7 of 7
Re: Ipod Touch
I am opted in and re-opted in again as Stormbringer said and still the same. No connection
And btw, my laptop doesn't even connect to either Fon or Openzone from the Hub either
