G4HLF
Message 1 of 3
Is ADSL filter different to VDSL?
Hi all,
Quick question.
Standard BT ADSL faceplate do it need upgrading if a customer upgrades to VDSL?
I was wondering if there is any difference in the filtering?
Regards,
Paul
2 REPLIES 2
Message 2 of 3
Re: Is ADSL filter different to VDSL?
A new filtered face plate will be fitted to the master socket which will do away with the need to have filters on any telephone extensions that you may have.
Message 3 of 3
It only filters the phone side of the circuit (low pass filter), so the ADSL/VDSL simply passes through unaffected. So it does not matter which type you use.
