Message 1 of 12
Is YVM105 a software bug or hardware?
i keep getting the YVM105 error on my Players. If it's a software issue I don't mind waiting for an update to fix it, but if it's a hardware bug I guess I need to get my box replaced. Does anyone know if a fauty box could cause this problem? done all the various resets and that hasn't fixed it
11 REPLIES 11
Message 2 of 12
Re: Is YVM105 a software bug or hardware?
Message 3 of 12
Tried all those steps, still no luck Smiley Sad
if its a software issue i dont mind waiting around but if its hardware i guess i need to escalate it, which is why im trying to find out
Message 4 of 12
so are getting the error at all times or just periodically ?
Were your players working normally before if so roughly when did you start experiencing the problems.
Is the problem on each and every player ?
Do you have BT Tv Ip channels and do they play normally ?
Which Youview box are you using and what is the current (manufacture) software  version ?
Message 5 of 12
i ONLY get the error with netflix.
all other players work perfectly (iplayer, 4, itv).
netflix on other devices works fine (including bt db t2200 - works fine).
i don't have any iptv channels right now, but i used to and they used to work fine.
it is the 4K box, all software + players up to date (29.45.0).
i've never tried netflix before on this box because i used the app on my tv before
Message 6 of 12
So this thread isn't about 'YVM105'. Its about 'I can't connect to Netflix'.
A poor thread title then and TBH you should have stated from the off what your problem was. As it honestly helps others to help you.
Message 7 of 12
Message 8 of 12
🙄 except when I launch Netflix it says YVM105 ERROR. TRY AGAIN LATER etc.
Message 9 of 12
And thanks for the link but I'd already tried those steps before starting this thread. As the post says, the message I get is a YVM105 ERROR, that page refers to another error
Message 10 of 12
Which is why I'm aiming to find out if YVM105 is a software or hardware bug, and if BT need to send me a new box
