Message 1 of 3
Is it normal for connection to be unusable during first 10 days learning?
Hi,
Moved into new house and had HH3 delivered on 8th (no broadband light) Engineer came on 15th and actually connected line to broadband at exchange.
Since then, most of the time the broadband is unusable (so many errors that hardley any good packets arrive) this is when the Noise margin is below 6dB (which is most of the time during the day) when the Noise margin is above 6dB then the errors go away and I have a functioning connection (but this is only very early in the morning or very late at night)
Is this normal?
Shouldn't the learning system look at the error rates and modify the connection to improve the connection?
Also on HH3 are the Error Seconds really Error tenths of seconds as this value would be longer than the connection time if seconds.
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 22:12:24
Downstream: 1.625 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Fast
Noise margin (Down/Up): 5.5 dB / 18.0 dB
Line attenuation (Down/Up): 52.2 dB / 29.5 dB
Output power (Down/Up): 15.7 dBm / 11.7 dBm
FEC Events (Down/Up): 0 / 22830
CRC Events (Down/Up): 1658066 / 1212
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 1947466 / 2640
Error Seconds (Local/Remote): 85391 / 25737
ADSL Line Status
Connection time: 1 days, 11:46:46
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 3.5 dB / 18.0 dB
FEC Events (Down/Up): 0 / 31237
CRC Events (Down/Up): 1896656 / 1555
HEC Events (Down/Up): 2369755 / 3319
Error Seconds (Local/Remote): 92026 / 29373
Andy
2 REPLIES 2
Message 2 of 3
Re: Is it normal for connection to be unusable during first 10 days learning?
unless you are a gamer the I would request that you are changed fron 'fast' to 'interleaved' which should make your connection more stable  contact the mods via this link  http://bt.custhelp.com/app/contact_email/c/4951
I thought 21CN would have changed automatically seeing the error problem
Distinguished Guru
Message 3 of 3
Even if you are a gamer, you should find that your connection becomes a lot more stable if switched to Interleaved.  I can't think why it's currently set to Fast.
If it were interleaved, most of the CRC errors would become FEC errors, which are silently fixed by the router.
