goral
Message 1 of 8
Is it normal or is something wrong with my connection or HUb?
Hi.
Is it normal that the speed jumps from 800KB/s to 56KB/s when I download at this same time large file from one server?
Or is smashing wrong with my speed (connection) or Hub (ver.A)
7 REPLIES 7
Message 2 of 8
Re: Is it normal or is something wrong with my connection or HUb?
can you post the adsl stats from your router may need to show detail to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z) and run btspeedtester http://speedtester.bt.com and post the results. Someone may then be able to offer assistance
goral
Message 3 of 8
Thanks for reply:)
Bottom I paste speed test result and ADSL stat.
Jumping speed is very irritating. When I download large files (more then 100MB per file) from rapidshare speed show in FlasGet jumping from 800KB/s to 56KB/s sometimes is 124, 530, 170 etc... Is very unstable.
Before I been with VM (cable area) and speed was very stabile. Jumping from 1180KB/s to 1010KB/s sometimes 970KB/s but not to 120 or below 100KB/s.
That I ask in ADSL is normal? Or is something wrong with my line/equipment.
Thanks.
Speed test:
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
    Download Speed
    3246 Kbps
0 Kbps    7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 3246 Kbps
 For your connection, the acceptable range of speedsis 2000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :10424 Kbps(DOWN-STREAM), 944 Kbps(UP-STREAM)
 IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 7.54:16.41:76.08 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
    Upload Speed
    722 Kbps
0 Kbps    944 Kbps
>Upload speed achieved during the test was - 722 Kbps
 Upstream Rate IP profile on your line is - 944 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
ADSL Stats:
ADSL line status
Connection information
Line state    Connected
Connection time    8 days, 14:14:04
Downstream    10,426 Kbps
Upstream    944 Kbps
ADSL settings
VPI/VCI    0/38
Type    PPPoA
Modulation    ITU-T G.992.5
Latency type    Interleaved
Noise margin (Down/Up)    8.4 dB / 5.3 dB
Line attenuation (Down/Up)    31.0 dB / 15.5 dB
Output power (Down/Up)    20.9 dBm / 12.4 dBm
Loss of Framing (Local)    0
Loss of Signal (Local)    0
Loss of Power (Local)    0
FEC Errors (Down/Up)    598212 / 3328
CRC Errors (Down/Up)    275 / 2147480000
HEC Errors (Down/Up)    nil / 69776
Error Seconds (Local)    214
Message 4 of 8
check here to see if problemwith your exchange
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
goral
Message 5 of 8
Every things on this links looks fine.
From first link: There is not my exchange
From second: first two information is green:
1. VP capacity at this exchange is currently showing as Green. Click here for further details
2. BT have advised that this exchange is enabled for WBC on 21CN
status other two is grey:
3. You can view recent Service Outages for this exchange here
4. BT has published DSL Max upgrade information for this exchange
Last link not showing my area.
So with exchange anything looks fine, haw to test my BT Hub?
Message 6 of 8
your profile is a bit low for your speed as I would expect 9000 not 8000 but if you maintain connection this should change on it's own.  The speed at which you download can change from site to site as many restrict the download speed as their servers cannot handle every user downloading at their max speed.
Distinguished Guru
Message 7 of 8
The "information superhighway" suffers from traffic jams from time to time just like real roads.  There's no guarantee that the speed at which you can download from a web site somewhere else in the World will be fast or consistent.
goral
Message 8 of 8
I don't think is problem with other sever, be cous I used rapidshare for more then 3 years, and always I get max my speed. Is not different in BT, but in BT speed is very unstable.
So I just wonder it is connection problem with my exchange or equipment I have.
