ksmiles
Message 1 of 4
Is it possible to stop broadcasting BTopenzone
Hi everyone so i got one of these old school hubs
http://postimage.org/image/q3a36w14l/
And im broadcasting Btopenzone is there anyway to disable this.
I had 30 people connect to me about a week ago all from Iphones shows up when i log into my Hub
the ips all started with 10.???.???.??? (Thought that was for only Fon those ips too Man Surprised
I thought open zone was for like business places cafes and what not.
I dont have any of these nor am i a business user.
So if anyone got a little tips be very grateful.
3 REPLIES 3
DS
Distinguished Guru
Message 2 of 4
Re: Is it possible to stop broadcasting BTopenzone
Hi ksmiles and welcome
A BT Business hub used on a residential connection will only transmit BTOpenzone (now called BTWifi).
Residential hubs will transmit BTOpenzone and BTFon (BTWifi and BTWifi-with-fon).
To remove this you need to opt out of BTWifi and your hub should receive an update in around 48 hours.
Opt out using this - http://bt.custhelp.com/app/answers/detail/a_id/12958/c/346,1238,2694
Note: You won't be able to connect to other BTWifi zones for free after opting out.
-+-No longer a forum member-+-
ksmiles
Message 3 of 4
Thanks for reply was just curious thats all.
I like having it was just curious if i wanted to disable it could i
so thanks again.
DS
Distinguished Guru
Message 4 of 4
Ok, no problem:).
If you're not bothered then leave as is, if you don't want it, it's all there above;)
