henburyman
Message 1 of 11
Is it worth me paying for Infinity 2?
Please can anyone advise me whether I would get worse speeds on Infinity 1 than these. I am 700 metres from my Cabinet.
Here's my test results.
Hope someone can help!
10 REPLIES 10
ray_dorset
Distinguished Guru
Message 2 of 11
Re: Is it worth me paying for Infinity 2?
The only difference between Infinity 1 and Infinity 2 is that 1 has a cap at 40 Mbps down and 10Mbps up. Infinity 2 has a cap at 80 Mbps down and 20 Mbps up. As you're nowhere near the cap, there would be no difference.
If not, I'll try again 🙂
ray_dorset
Distinguished Guru
Message 3 of 11
However, it does look like DLM has been active on your connection. How long have you had Infinity?
henburyman
Message 4 of 11
I've had it about 2 years now, and my speed is about 5mbs slower than when I first had it. I did buy a HH5 about six months ago. What is DLM?
ray_dorset
Distinguished Guru
Message 5 of 11
Dynamic Line Management (DLM) is an automatic monitoring system that counts errors and disconnections on your connection and changes the line parameters to achieve stability.
The line parameters include changing the SNR margin and changing the rate of interleaving.
I notice from your line stats you had a connection time of 31 minutes. Did you disconnect on purpose?
henburyman
Message 6 of 11
Thanks for all the info Ray. Yes, I reset the HH5 because it said to do that before doing the speed test. I think I'll be in touch with BT tomorrow to "downgrade" to Infinity 1, and save myself £3 per month.
pippincp
Sage
Message 7 of 11
Looking at the stats you've posted Infinity 2 is a waste of time and money for you.
henburyman
Message 8 of 11
BTW, do people who get 50mbs upwards live on top of the cabinets? lol
ray_dorset
Distinguished Guru
Message 9 of 11
My cab is at the end of my road about 150-200m away
pippincp
Sage
Message 10 of 11
No, they just have better lines. I had no problem with speeds when on Infinity 1.
