Message 1 of 6
Is my hub fibre compatible?
Hi - my hub looks to be the right one but none of the ports on the back are red - it’s called smart hub 2 and has 4x Ethernet ports (all coloured yellow), 1 x digital phone port and 1 x broadband port  Also, who provides the backup 4g router - does it come from BT or do openreach install and leave it?
thanks, Ian
5 REPLIES 5
Message 2 of 6
Re: Is my hub fibre compatible?
If you are getting FTTP then hub needs WAN port so not any good and will need a replacement which BT should supply along with 4g if selecting hybrid halo 3+
Message 3 of 6
@imjolly That's not quite true. SH2 can now do both FTTP or standard broadband. There is a button in Advance settings  in "Broadband" menu where Ethernet port 4 can be for FTTP or normal LAN. If you go into that menu and click on "?" it will give you the details.
I can't remember which firmware brought the duel functionality into play though.
Message 4 of 6
Thanks both for the swift replies which really help - sounds like I need to get onto BT to sort out the 4g router and that the smart hub will do the job,
thanks again
Message 5 of 6
V26 did, You can use any SH2 with FTTP now.
Message 6 of 6
Yeah, Dippu is right. BT have updated the Smart Hub 2 so that you can change the 4th LAN Port to a WAN.
They say it’s so people don’t have to change all their WIFI Passwords but what they really mean is they don’t have to go to the cost of sending a new Smart Hub 2.
