jaammeess
Newbie
Message 1 of 2
Is the Securifi Almond compatible with the BT home hub 3.0 router?
Just wandering before I purchase it 🙂
1 REPLY 1
Moderator-Retired
Message 2 of 2
Re: Is the Securifi Almond compatible with the BT home hub 3.0 router?
I wouldn't think so, from what I can see. You'd need to buy a separate DSL modem in order to get a connection.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
