In the dim & distant past I used to run a Netgear DG834 and IMHO it was probably the best router I have owned. Sadly it met its end when being used by a relative. I think a power spike bricked it.
Anyhow I was wondering if anyone out there knows of a similarly configurable and not dumbed down VDSL router for use on Infinity.
IMHO the Smart (sic) Hub appears to be intended for a 5-year old or younger
Solved! Go to Solution.
This has been discussed many times on this forum.
The TP-LINK TD-W9980 N600 is the most recommended.
The cheapest vdsl modem/ router is the tp link td- w9970
It depends on how much you want to pay.
The w9980 needs a firmware flash when using B.T T.v and many are refurbished models with just a 6 months warranty.
A heighbour has one and is pleased for the £55 price.
@cooljay wrote:The w9980 needs a firmware flash when using B.T T.v
It did about 2 years ago.
A friend who bought his from the high street was on a firmware from 2013!!!
This was about 5 months ago.
Just shows how many are made and when.
No, it shows how few the high st vendor shifts.
Currys/PC World still have a few 9980s for £49.
@TimCurtis wrote:Currys/PC World still have a few 9980s for £49.
Good price, they are discontinued now but Amazon are trying to shift them at £118 which is crazy as the VR600 is now only £75
Just purchased a VR600 @ £75 as an alternative to my HH6, the VR600 is a peach to setup.
Only niggle I have with it at present is though IPV6 compliant, it's not BT's usage of IPV6 compliant yet. I understand from an earlier posting in the forum TP-Link are working on a new firmware for it.
@Oddius09 wrote:@Just purchased a VR600 @ £75 as an alternative to my HH6, the VR600 is a peach to setup.
It will work okay, though, with equipment connecting using native IPv6. The router itself doesn't get an IPv6 address because the VR600 doesn't yet support the BT /56 prefix but TP-Link are working on new firmware to fix that. There's also a question mark over whether the router's firewall is operating properly with IPv6 connections, so it's worth ensuring that software firewalls are in place. Again, TP-Link are aware and say they will fix that.
p
