Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Is there a simple way to keep an iPhone 6 connected to BT superfast broadband?
Since "upgrading" to the faster service my Iphone (have tried a 5 and a 6) does not stay connected to the wifi and takes a very long time to reconnect. It's virtually unusable.
It rarely shows the wifi icon and often shows the 3g and 4g icons instead. We don't even get 3g and 4g in our area, nor does the phone serve any internet when showing the 3g/4g icons.
I have tried the double channel options on the new Smart Hub router to no avail.
BT advised me to tried a wired connection which was not very helpful for an Iphone.....
I had no issues whatsoever before the upgrade and would really prefer BT just downgraded me but it seems to be a one way street.
Any advice much appreciated.
Solved! Go to Solution.
Welcome to this user forum.
Usually splitting the channels so that the 5G channel has a "5" added to the end, and making sure that the iPhone only connects to the 2.4GHz channel, solves the problem.
Its important that you delete any reference to the 5GHz connection on the iPhone, otherwise it will try to swap between the two, and lose connection in the process.
Here is an example screen.
Thanks so much for your prompt response.
BT took 8 weeks to come back with nothing ; you have made a helpful suggestion after 8 minutes......
I will do as you suggest and come back to the forum to report the results.
Many Many Many thanks for your help.
My daughter had the same issue with an iPhone and a laptop, and it sorted out the connection problem.
Sadly its gone already. Lost internet, 4G showing but nothing coming through and can't convince the phone that its not connected.
Back to the drawing board. (Preferably back to my old router and internet contract...if only.....)
Did you succeed in splitting the wireless bands? If you did, you should see the 5GHz SSID being transmitted with a "5" on the end?
I already had split the bands.
I removed the -5 one from the phone's chosen connection options
The phone now wants to use the non existent 4G connection and can't get through to the internet.
It had been ok on the 2.4ghz connection for a few hours
Okey dokey.
Try first resetting netwwork connections on the iphone (settings - general - reset - reset netwprk settings) then try to connect to the Smart Hub.
if that doesn't work, you may need to set a static ip for the phone.
See here.
Have you tried going into your phone's wifi settings and entering them yourself.
Go go into Settings, Wifi, click on your hubs name. Some dhcp settings should appear. Copy them down. Click on static and enter your settings there. Then click back and it should be saved. You may need to turn phone off and on.
Thanks.
For the static ip set up the links says
"enter these settings IP address: 192.168.1.xxx"
Is that literally xxx (three x's) or should it be a number ?
