Message 1 of 5
Is there a way to edit the Subject line on emails received (inbox)?
When using MS Outlook, I frequently edited the email subject line so as to make it easier to search folders for specific emails. This also helps to get a useful order when sorting email alphabetically.
However, it seems I can't do this with BT Email, or is there a way to do this?
Thank you.
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Is there a way to edit the Subject line on emails received (inbox)?
Do you mean emails in your inbox or are you looking to change the subject line when your reply to an email?
Message 3 of 5
I mean the subject line on emails received, in my inbox.  I could then amend so that the subject line actually relates to the subject (or content or sender) to make them easier to find after I have saved to a folder.
Anonymous
Not applicable
Message 4 of 5
No way to change the subject line in your inbox that I know of but you can usually create and assign your own tags.
Message 5 of 5
Thanks anyway.
Disappointing. You'd think this would be a relatively simple addition to functionality, and it would be very useful. However, if it can't be done I guess my option is to revert to using Outlook and enjoying the many additional features it offers.
Thanls again.
Ken
