Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Just a quick question or maybe a call for clarification. I currently have no Broadband, my smart hub is constantly flashing purple, I reported it to the help desk, did all the tests, I replaced the cables, plugged into the test socket,changed the filter, I even swapped out the smart hub as I have a working spare. And it is still flashing purple away to itself..Now considering I have no connection at all(though the phone still works) is it normal to be told it will take over a week(that's over a week without a BB connection) before someone can be spared to investigate the problem ?.
Ah ok ...and can I claim back for the time without a BB connection ?.
Which exchange are you on?
Not sure..But I live in Darlington Co Durham, along Neasham Road, So I have to assume it is the one in Darlington town center.
Yes that's it... Happened right after/during a thunder storm. But I disconnect my router from wall and power when not in use, so its not as if a strike would have affected the equipment in the house anyway.
@Flyntlock wrote:Not sure..But I live in Darlington Co Durham, along Neasham Road, So I have to assume it is the one in Darlington town center.
Thanks for that. I just wanted to check if there was an area problem caused by a cut ducting or cabinet problem etc in your area on the Openreach site.
As there's nothing then it must be a fault specific to you, either your line or the Hub.
