Message 2 of 3
Is this normal?
22:26:52 09 Oct. ARP [add] br0(wl1) 192.168.1.192 ce:71:cb:a9:0a:93
22:26:52 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
22:26:52 09 Oct. Receive a DHCP request
22:26:47 09 Oct. 5G WiFi scan(Reason:boot)
22:26:46 09 Oct. 2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
22:26:44 09 Oct. 2.4G WiFi scan(Reason:boot)
22:26:39 09 Oct. Has a problem to connect to SAAF framework (4 times)
22:26:37 09 Oct. 2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
22:26:37 09 Oct. Booting firmware v0.27.06.04290-BT (Thu Apr 29 20:28:10 2021)
22:26:34 09 Oct. System start Button press (PowerButton)
22:26:34 09 Oct. System up
22:26:27 09 Oct. 2.4G WiFi scan(Reason:boot)
22:26:23 09 Oct. Hub has activated against the device management system
22:26:23 09 Oct. 2.4G WPS feature enabled
22:26:23 09 Oct. 2.4G WPA2 mode selected
22:26:23 09 Oct. 2.4G WiFi UP
22:26:23 09 Oct. 5G WPS feature enabled
22:26:23 09 Oct. 5G WPA2 mode selected
22:26:23 09 Oct. 5G WiFi UP
22:25:37 09 Oct. System restart reason: Unknown
22:24:18 09 Oct. admin timeout from 192.168.1.192
22:23:42 09 Oct. admin login success from 192.168.1.192
22:23:10 09 Oct. admin timeout from 192.168.1.192
22:21:14 09 Oct. NTP synchronization success
22:21:14 09 Oct. NTP Server: ntp.homehub.btopenworld.com
22:21:01 09 Oct. NTP synchronization start
22:13:56 09 Oct. CWMP: HDM socket closed successfully.
22:13:56 09 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
22:13:55 09 Oct. CWMP: HDM socket opened successfully.
22:13:55 09 Oct. CWMP: HDM socket closed successfully.
22:13:55 09 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
22:13:55 09 Oct. CWMP: session completed successfully
22:13:54 09 Oct. CWMP: HDM socket opened successfully.
22:13:53 09 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
22:13:53 09 Oct. CWMP: Session start now server: https://pbthdm.x.x.x Event code: 2 PERIODIC
22:13:53 09 Oct. CWMP: Initializing transaction for event code 2 PERIODIC
22:10:30 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
22:09:53 09 Oct. 2.4G client Mac: 2E:7F:26:F3:78:C8 Deauthentications (Reason:Disassociated due to inactivity )
22:07:10 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
22:03:13 09 Oct. 2.4G client Mac: 08:3D:88:A3:05:AD Deauthentications (Reason:Disassociated due to inactivity )
22:01:16 09 Oct. ARP [add] br0(wl0) 192.168.1.219 7e:1a:76:88:7f:40
22:01:11 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
22:01:11 09 Oct. DHCP device Connected: 192.168.1.219 7e:1a:76:88:7f:40 Galaxy-A52-5G
22:01:11 09 Oct. 5G Client associate from 7e:1a:76:88:7f:40 (IP=192.168.1.219) RSSI=-59 Rate=433Mbps host Galaxy-A52-5G
22:01:11 09 Oct. LAN [ADD] ARP 192.168.1.219 with 7e:1a:76:88:7f:40 from br0(wl0)
22:01:10 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
22:01:10 09 Oct. Receive a DHCP request
22:01:10 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(7E:1A:76:88:7F:40)(Legacy Device) join WHW infrastructure
22:01:10 09 Oct. WHW INFO A station STA(7E:1A:76:88:7F:40) leave WHW infrastructure
22:00:56 09 Oct. DHCP device Disconnected: 192.168.1.219 7e:1a:76:88:7f:40 Galaxy-A52-5G
22:00:56 09 Oct. LAN [DEL] ARP 192.168.1.219 with 7e:1a:76:88:7f:40 from br0
22:00:52 09 Oct. ARP [del] br0 192.168.1.219 7e:1a:76:88:7f:40
21:59:21 09 Oct. ARP [add] br0(wl0) 192.168.1.219 7e:1a:76:88:7f:40
21:59:17 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
21:59:17 09 Oct. DHCP device Connected: 192.168.1.219 7e:1a:76:88:7f:40 Galaxy-A52-5G
21:59:16 09 Oct. 5G Client associate from 7e:1a:76:88:7f:40 (IP=192.168.1.219) RSSI=-50 Rate=390Mbps host Galaxy-A52-5G
21:59:16 09 Oct. LAN [ADD] ARP 192.168.1.219 with 7e:1a:76:88:7f:40 from br0(wl0)
21:59:16 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
21:59:16 09 Oct. Receive a DHCP request
21:59:16 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(7E:1A:76:88:7F:40)(Legacy Device) join WHW infrastructure
21:59:16 09 Oct. WHW INFO A station STA(7E:1A:76:88:7F:40) leave WHW infrastructure
21:58:41 09 Oct. DHCP device Disconnected: 192.168.1.219 7e:1a:76:88:7f:40 Galaxy-A52-5G
21:58:41 09 Oct. LAN [DEL] ARP 192.168.1.219 with 7e:1a:76:88:7f:40 from br0
21:58:36 09 Oct. ARP [del] br0 192.168.1.219 7e:1a:76:88:7f:40
21:48:49 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
21:44:53 09 Oct. 2.4G client Mac: 66:91:5F:A9:9E:F0 Deauthentications (Reason:Disassociated due to inactivity )
21:29:52 09 Oct. 2.4G client Mac: 0A:1D:2A:F9:D1:2A Deauthentications (Reason:Disassociated due to inactivity )
21:20:28 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
20:47:03 09 Oct. ARP [add] br0(wl0) 192.168.1.241 56:03:cc:32:b8:52
20:46:56 09 Oct. 2.4G Client disassociate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=0 Rate=0Mbps
20:46:55 09 Oct. 2.4G client Mac: 56:03:CC:32:B8:52 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
20:46:52 09 Oct. DHCP device Connected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
20:46:52 09 Oct. LAN [ADD] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0(wl0)
20:46:50 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(56:03:CC:32:B8:52)(Legacy Device) join WHW infrastructure
20:46:50 09 Oct. Self roaming might be occurring... Deauth original one...
20:45:23 09 Oct. ARP [add] br0(wl1) 192.168.1.241 56:03:cc:32:b8:52
20:45:19 09 Oct. DHCP device Connected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
20:45:18 09 Oct. LAN [ADD] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0(wl1)
20:45:18 09 Oct. 5G Client disassociate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=0 Rate=0Mbps
20:45:18 09 Oct. WHW INFO A station (SmartHub2)IF[2.4G](EC:6C:9A:A3:AF:04):STA(56:03:CC:32:B8:52)(Legacy Device) join WHW infrastructure
20:45:18 09 Oct. WHW INFO A station STA(56:03:CC:32:B8:52) leave WHW infrastructure
20:04:19 09 Oct. 2.4G client Mac: 5A:96:19:97:6C:BA Deauthentications (Reason:Disassociated due to inactivity )
19:29:49 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
19:10:57 09 Oct. 2.4G client Mac: EE:D4:90:36:F9:34 Deauthentications (Reason:Disassociated due to inactivity )
18:53:39 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
18:53:09 09 Oct. 2.4G client Mac: B0:C1:9E:69:D9:D3 Deauthentications (Reason:Disassociated due to inactivity )
18:49:49 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
18:36:28 09 Oct. 2.4G client Mac: 0A:4F:8D:C5:8B:60 Deauthentications (Reason:Disassociated due to inactivity )
18:30:18 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
18:06:57 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
18:03:50 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:53:37 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:49:47 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:49:47 09 Oct. 2.4G client Mac: 2E:32:E9:81:2D:37 Deauthentications (Reason:Disassociated due to inactivity )
17:40:55 09 Oct. 2.4G client Mac: 6E:7C:45:37:8C:17 Deauthentications (Reason:Disassociated due to inactivity )
17:40:16 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:35:16 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:34:46 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:31:56 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:30:16 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:20:16 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:16:25 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
17:02:31 09 Oct. 2.4G client Mac: 5E:1F:45:F9:2A:3A Deauthentications (Reason:Disassociated due to inactivity )
16:59:45 09 Oct. 2.4G client Mac: 86:3E:57:D7:92:99 Deauthentications (Reason:Disassociated due to inactivity )
16:59:14 09 Oct. 2.4G client Mac: B2:01:BA:9C:C2:4C Deauthentications (Reason:Disassociated due to inactivity )
16:54:06 09 Oct. ARP [add] br0(wl0) 192.168.1.241 56:03:cc:32:b8:52
16:54:01 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
16:54:01 09 Oct. DHCP device Connected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
16:54:01 09 Oct. 5G Client associate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=-48 Rate=780Mbps host Sid-s-S21
16:54:01 09 Oct. LAN [ADD] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0(wl0)
16:54:00 09 Oct. Receive a DHCP request
16:54:00 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
16:54:00 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(56:03:CC:32:B8:52)(Legacy Device) join WHW infrastructure
16:44:31 09 Oct. ARP [del] br0 192.168.1.241 56:03:cc:32:b8:52
16:43:46 09 Oct. DHCP device Disconnected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
16:43:46 09 Oct. LAN [DEL] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0
16:43:45 09 Oct. 5G Client disassociate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=0 Rate=0Mbps
16:43:43 09 Oct. WHW INFO A station STA(56:03:CC:32:B8:52) leave WHW infrastructure
16:30:15 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
16:28:11 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
16:28:04 09 Oct. 2.4G client Mac: 46:21:A6:13:31:CE Deauthentications (Reason:Disassociated due to inactivity )
16:26:24 09 Oct. 2.4G client Mac: 82:76:9F:04:B6:AA Deauthentications (Reason:Disassociated due to inactivity )
16:18:35 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
16:16:23 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
16:08:35 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
16:00:49 09 Oct. 2.4G client Mac: 0A:14:A2:B6:E9:66 Deauthentications (Reason:Disassociated due to inactivity )
16:00:43 09 Oct. 2.4G client Mac: A0:99:9B:5E:78:5A Deauthentications (Reason:Disassociated due to inactivity )
16:00:14 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:56:22 09 Oct. 2.4G client Mac: 62:2B:68:92:D1:78 Deauthentications (Reason:Disassociated due to inactivity )
15:55:24 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:50:14 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:48:45 09 Oct. 2.4G client Mac: 10:D3:8A:D2:04:13 Deauthentications (Reason:Disassociated due to inactivity )
15:41:54 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:38:33 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:38:08 09 Oct. ARP [add] br0(wl0) 192.168.1.241 56:03:cc:32:b8:52
15:38:05 09 Oct. DHCP device Connected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
15:38:04 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:38:04 09 Oct. 5G Client associate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=-45 Rate=780Mbps host Sid-s-S21
15:38:04 09 Oct. LAN [ADD] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0(wl0)
15:38:03 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:38:03 09 Oct. Receive a DHCP request
15:38:03 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(56:03:CC:32:B8:52)(Legacy Device) join WHW infrastructure
15:37:29 09 Oct. 2.4G client Mac: A6:F0:34:1A:9A:08 Deauthentications (Reason:Disassociated due to inactivity )
15:36:36 09 Oct. 2.4G client Mac: 26:66:00:6D:45:B8 Deauthentications (Reason:Disassociated due to inactivity )
15:34:42 09 Oct. 2.4G client Mac: 6A:32:B3:86:ED:7D Deauthentications (Reason:Disassociated due to inactivity )
15:34:42 09 Oct. 2.4G client Mac: 2E:B3:00:20:D6:65 Deauthentications (Reason:Disassociated due to inactivity )
15:31:22 09 Oct. 2.4G client Mac: DA:3C:28:CF:11:0C Deauthentications (Reason:Disassociated due to inactivity )
15:21:53 09 Oct. ARP [del] br0 192.168.1.241 56:03:cc:32:b8:52
15:21:23 09 Oct. DHCP device Disconnected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
15:21:23 09 Oct. LAN [DEL] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0
15:21:22 09 Oct. 5G Client disassociate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=0 Rate=0Mbps
15:21:22 09 Oct. WHW INFO A station STA(56:03:CC:32:B8:52) leave WHW infrastructure
15:20:13 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:03:27 09 Oct. 2.4G client Mac: 04:D6:AA:51:D6:8E Deauthentications (Reason:Disassociated due to inactivity )
15:02:49 09 Oct. ARP [add] br0(wl0) 192.168.1.192 0a:a1:5a:16:fc:af
15:02:04 09 Oct. 2.4G Client disassociate from 0a:a1:5a:16:fc:af (IP=192.168.1.192) RSSI=0 Rate=0Mbps
15:02:03 09 Oct. 2.4G client Mac: 0A:A1:5A:16:FC:AF Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS)
15:02:01 09 Oct. DHCP device Connected: 192.168.1.192 0a:a1:5a:16:fc:af Ian-s-S21
15:02:00 09 Oct. LAN [ADD] ARP 192.168.1.192 with 0a:a1:5a:16:fc:af from br0(wl0)
15:01:59 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(0A:A1:5A:16:FC:AF)(Legacy Device) join WHW infrastructure
15:01:59 09 Oct. Self roaming might be occurring... Deauth original one...
15:01:02 09 Oct. ARP [add] br0(wl0) 192.168.1.241 56:03:cc:32:b8:52
15:00:57 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:00:57 09 Oct. DHCP device Connected: 192.168.1.241 56:03:cc:32:b8:52 Sid-s-S21
15:00:56 09 Oct. 5G Client associate from 56:03:cc:32:b8:52 (IP=192.168.1.241) RSSI=-51 Rate=780Mbps host Sid-s-S21
15:00:56 09 Oct. LAN [ADD] ARP 192.168.1.241 with 56:03:cc:32:b8:52 from br0(wl0)
15:00:56 09 Oct. Receive a DHCP request
15:00:56 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:00:56 09 Oct. WHW INFO A station (SmartHub2)IF[5G](EC:6C:9A:A3:AF:03):STA(56:03:CC:32:B8:52)(Legacy Device) join WHW infrastructure
15:00:15 09 Oct. ARP [add] br0(wl1) 192.168.1.192 0a:a1:5a:16:fc:af
15:00:11 09 Oct. DHCP device Connected: 192.168.1.192 0a:a1:5a:16:fc:af Ian-s-S21
15:00:11 09 Oct. 2.4G Client associate from 0a:a1:5a:16:fc:af (IP=192.168.1.192) RSSI=-55 Rate=192Mbps host Ian-s-S21
15:00:11 09 Oct. LAN [ADD] ARP 192.168.1.192 with 0a:a1:5a:16:fc:af from br0(wl1)
15:00:11 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:00:10 09 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:00:10 09 Oct. WHW INFO A station (SmartHub2)IF[2.4G](EC:6C:9A:A3:AF:04):STA(0A:A1:5A:16:FC:AF)(Legacy Device) join WHW infrastructure
15:00:10 09 Oct. Receive a DHCP request
14:58:01 09 Oct. 2.4G client Mac: A2:8C:F2:F9:10:D7 Deauthentications (Reason:Disassociated due to inactivity )
14:43:00 09 Oct. 2.4G client Mac: E2:F1:83:C8:FE:D5 Deauthentications (Reason:Disassociated due to inactivity )
14:41:20 09 Oct. 2.4G client Mac: 2A:AA:6F:2B:8F:C5 Deauthentications (Reason:Disassociated due to inactivity )
2 REPLIES 2
Message 1 of 3
Please phone,smart hub seems hacked
Hi my phone and router seem to be doing very unusual out of character events and I'm worried my WiFi has been hacked
Message 3 of 3
Re: Please phone,smart hub seems hacked
Change the WiFi code then.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
