PaddyB
Moderator
Moderator
Message 1 of 5
Issue with Smut Filter
Hi Guys,
Just to give you a quick heads up, there is a problem with the smut filter not working at the moment. We've raised this with Lithium.
If you happen to see any words making it onto the forum that shouldn't, please can you let me know.
PaddyB
4 REPLIES 4
stuartrogerson
Distinguished Guru
Message 2 of 5
Re: Issue with Smut Filter
Will do
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Message 3 of 5
Will watch out for the filter.
I was going to create a new topic on a separate subject which seems to be very hot at the moment.
This one takes priority, so will leave it, as it will only distract.
pottyperson
Distinguished Guru
Distinguished Guru
Message 4 of 5
I think it's been fixed. My friend Richard is again unable to sign with the universally recognised abbreviation of his name.
JohnC2
Moderator
Moderator
Message 5 of 5
Hi All, @PaddyB was testing this before he left the office and confirmed it's now fixed.
cheers
John
