jopnew
Message 1 of 24
Issue with download speeds
I have been helping out a family friend in his 70's. His broadband speeds have dropped dramatically over the past couple of months.
We have tested everything.
1) We had a line check came back as OK
2) We checked and changed the filter
3) We checked the cable from the filter to the router
4) We reset the router
5) I have now tried the connection on two differenct machines.
We have checked everything.
The connection used to be fine. This only started happening when the exchange was upgraded to Infinity in our area.
I don't believe it is anything to do with our end, and I wish someone from BT could see if it is anything to do with the exchange, because something is not right here.
Take a look at the downstream, it is appalling. Any pointers.
Here are the stats
ADSL Line Status
Connection Information
Line state:    Connected
Connection time:    0 days, 00:31:53
Downstream:    287.1 Kbps
Upstream:    1.126 Mbps
ADSL Settings
VPI/VCI:    0/38
Type:    PPPoA
Modulation:    G.992.5 Annex A
Latency type:    Interleaved
Noise margin (Down/Up):    24.5 dB / 5.2 dB
Line attenuation (Down/Up):    19.3 dB / 12.7 dB
Output power (Down/Up):    18.3 dBm / 12.4 dBm
FEC Events (Down/Up):    334 / 117
CRC Events (Down/Up):    0 / 16
Loss of Framing (Local/Remote):    0 / 0
Loss of Signal (Local/Remote):    0 / 0
Loss of Power (Local/Remote):    0 / 0
HEC Events (Down/Up):    0 / 89
Error Seconds (Local/Remote):    0 / 2
23 REPLIES 23
imjolly
Message 2 of 24
Re: Issue with download speeds
you are in abanded profile due to either noise on the line causing drops in connection or to many manual resets trying to improve the speed or both.
are you connected to the master socket or preferably the test socket?  do you have any other sockets in other rooms?
try quiet line test  dial 17070 option 2  should hear nothing and best with corded phone  if cordless dull hum is normal
banding normally releases automatically if conenction ok and remains stable for 3/5 days with no resets
jopnew
Message 3 of 24
Thank you for your help. I can acutally try this tomorrow.
We are connected to the main socket. I presume I need to take the plate off the front and plug the filter in to the test socket?
If the speed improves in the test socket, what is the next step?
If the speed does not improve, what is the next step?
imjolly
Message 4 of 24
the speed will not improve immediatley as I explained you are in a banded profile and that will take 3/5 days to release but conencting to test socket should eliminate any noise problems caused by internal wiring and help connection stay stable
john46
Message 5 of 24
hi this link explains more about your speed reduction http://forumhelp.dyndns.info/speed/speed_drop.html
jopnew
Message 6 of 24
Again thank you for your help. I will get back with results on Sunday and see if we can improve the speed.
jopnew
Message 7 of 24
Looking at the document, very helpful as well as all your replies I will do the following.
We both live in the same town and are on the same exchange.
I remember the upgrade happening. I got an increase of about 5mb, so I get about 14mb download speeds, while my family friend download speed went down.
This is what I will I do:
I will use the test telephone number for noise on the line.
I will then remove the plate off the socket and plug the straight in to the test socket.
We will leave this untouched for a period of 10 days.
If the download speed does not improve then this must be to do with the exchange?
imjolly
Message 8 of 24
if possible can you post new stats after 3/5 days and see if the change to test has reduced errors and also line is still stable with no drops in connection
ryant704
Guru
Message 9 of 24
If it doesn't rise you will need to contact the moderators as your IP profile will be stuck which is rather quite common on ADSL. They will then reset your IP profile, then your speed should return.
Providing you maintained connected for 3/5 days as ImJolly said.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
imjolly
Message 10 of 24
ryant704
there is nothing wrong with the ip profile -- the problem is line is in a banded profile which is totally different.  it should release automatically but on odd times it does get stuck but time will tell
