I know that I'm jolly he states if the speed doesn't rise. But it will with 3/5 days connected but if he doesn't feel it, it will be due to IP profile that is stuck on the line.
Ryant 704 a banded profile rarely if ever needs manual resetting as the process is controlled by the DLM the process is fully automatic unlike stuck IP Profiles on the 20cn network again a stuck IP Profile on 21cn is very unusual
Neither of you are understanding where I am coming from.
He said if the speed doesn't rise which it will after 3/5 days the only way it won't rise is because maybe the IP profile is stuck, but that is unlikely like you said. He will be moved out of the banded profile and the IP profile causing the slow speed then...
I see what you mean but when banded profile releases then connection speed will increase not back to normal but better as noise margin drops. as conenction is adsl2 ip profile will change with the conenction speed and I have not seen any where ip profile has stuck on an adsl2 connection
I'm even more confused now lol.
What do you all suggest I do. I'm happy for the help.
@imjolly wrote:
@ryant704 wrote:Neither of you are understanding where I am coming from.
It's possible, I've had first hand experince. This being more than once... 😛
connect to test socket and post new stats in 3/5 days no resets after connecting to test socket
@ryant704 wrote:
I see what you mean but when banded profile releases then connection speed will increase not back to normal but better as noise margin drops. as conenction is adsl2 ip profile will change with the conenction speed and I have not seen any where ip profile has stuck on an adsl2 connectionIt's possible, I've had first hand experince. This being more than once... 😛
then none of them have posted on the forum
Will do. Hopefully we can get to the bottom of this issue.
