MarcCo61
Message 1 of 10
Issue with faceplate?
Hello. I recently noticed there was no dial tone on any of the handsets on my landline. Having spoken to BT I confirmed that there is a dial tone when a handset is plugged into the test socket behind the faceplate, but no dial tone when the handset is plugged into the front of the faceplate itself. I went through disconnecting everything from the extension sockets - phone, sky box, etc, but that made no difference. I then disconnected the extension cable at the faceplate, but there is still no dial tone at the front of the faceplate - there is still a dial tone at the test socket.
Does this mean there is a problem with the faceplate itself and is this something BT should replace with no charge? If not, is it possible to buy just the faceplate so I can change it myself?
any advice would be much appreciated!
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Issue with faceplate?
Welcome to this customer to customer forum @MarcCo61
Which one of these matches your master phone socket?
MarcCo61
Message 3 of 10
Hi Keith. Thank you for your reply. It's this one
iniltous
Recognised Expert
Message 4 of 10
If your removable panel is a standard NTE5 as in photo 1, there isn't much to go wrong it's a piece of plastic with a male plug and female socket and a IDC for extension wiring , if it's a filtered faceplate( photo 3 or 4)  there are some electronics that can fail....who is responsible for this (consumer panel)  is a grey area, Openreach are responsible upto the master socket, but this is arguably upto the master socket test port, the consumer panel may be the consumers responsibility, given the potential for charges is you call out Openreach on a line that's OK at the test port and that NTE5 filtered or non filtered consumer panels are cheap and easily obtained ,  I would just buy one and fit it yourself.
Keith_Beddoe
Message 5 of 10
They are very prone to failure, with the exact symptoms you describe.
BT would charge £130 to replace it, as its after the main test socket.
You can buy replacements, but they are likely to do the same.
I would recommend that you remove the whole faceplate, and replace it with one of these.
LINDY VDSL2 Microfilter Faceplate
These are of a much simpler design, and do not suffer from the same problem.
Meanwhile, all you can do is to use the test socket with a microfilter.
If you remove the whole of the faceplate, you will find the original test socket behind it, where the faceplate plugs into.
You can plug the microfilter into that one, if you prefer.
MarcCo61
Message 6 of 10
Hi Keith. Thank you for the advice - that makes perfect sense. I've ordered the Lindy VDSL2 - it should be here on Tuesday, so fingers crossed that will sort it
Keith_Beddoe
Message 7 of 10
There are two additional screws which totally remove the faceplate, as its a two part affair.
Once its unscrewed you should be left with this
But without the bottom section.
You will see the test socket where the Lindy unit plugs in and is secured by one of the pair of screws provided.
The back of the Lindy unit has the wiring for extensions, but only connections 2 and 5 are needed, so you can copy them from the old NTE.
I think there are instruction with it anyway.
CJT80
Recognised Expert
Message 8 of 10
You can also just buy a replacement VDSL Faceplate online. They are made on Openreach's behalf, but I see you have opted for a 3rd party one.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
MarcCo61
Message 9 of 10
Hi Keith. Lindy faceplate received today and fitted - took about 5 minutes; the problem is resolved, including on the extensions (2,3 and 5 were wired on the old faceplate so I just kept all three). The lines are clear as a bell too (whereas they were pretty crackly before).
Thanks again for pointing me in the right direction
Marc
Keith_Beddoe
Message 10 of 10
Marc
I am pleased that its now sorted Smiley Happy
Those Openreach ones are a source of many problems, there are just over engineered for the simple function they need to perform.
You will see that by looking at the circuit board, a lot of components to potentially fail.
Pin 3 is only needed for the very old dial phones, and some old external bells.
