I am having an issue whereby I can't see my website from BT Broadband but my Three network phone can see it. I have asked friends who are with Virgin Media and they can also not see it. I have been back and forth between godaddy support and BT support and no one can seem to resolve this issue. So far I know that it traces to ip 195.219.194.2 (ripe.net) and then a firewall blocks it to godaddy. I am really not sure what I can do the trace report shows time outs on 2 and 3 however this is apparently normal with BT Broadband.
Solved! Go to Solution.
As BT have said, hops 2 and 3 not responding is normal and nothing to be concerned about.
Where you see time outs after hop 12 is not necessarily a firewall. This is more likely caused by the device at hop 13 not having a 'route' back to the IP address you're sourcing the traceroute from.
Are you able to include the host name or IP address that you're trying to connect to so others using BT IP addresses can see if they see the same behaviour?
I tried from here with traceroute using ICMP, UDP and TCP and all fail at the same point as you saw.
smf22@lampu:~$ sudo traceroute -I 160.153.162.130 traceroute to 160.153.162.130 (160.153.162.130), 30 hops max, 60 byte packets 1 erx1 (192.168.1.1) 0.390 ms 0.460 ms 0.536 ms 2 * * * 3 * * * 4 31.55.186.184 (31.55.186.184) 13.058 ms 13.113 ms 13.115 ms 5 195.99.127.100 (195.99.127.100) 11.904 ms 11.954 ms 11.955 ms 6 peer5-BE6.telehouse.ukcore.bt.net (213.121.193.175) 14.720 ms 14.269 ms 14.248 ms 7 t2c4-et-8-1-0-0.uk-lon1.eu.bt.net (166.49.211.248) 11.278 ms 8.164 ms 8.169 ms 8 ix-ae-33-0.tcore2.LDN-London.as6453.net (80.231.20.1) 8.283 ms 8.330 ms 8.046 ms 9 * * * 10 if-ae-14-2.tcore2.AV2-Amsterdam.as6453.net (80.231.131.161) 15.472 ms 15.472 ms 16.922 ms 11 if-ae-2-2.tcore1.AV2-Amsterdam.as6453.net (195.219.194.5) 16.234 ms 16.113 ms 16.066 ms 12 195.219.194.2 (195.219.194.2) 14.918 ms 14.461 ms 14.975 ms 13 * * * 14 [snip] 30 * * * smf22@lampu:~$ sudo traceroute -U 160.153.162.130 traceroute to 160.153.162.130 (160.153.162.130), 30 hops max, 60 byte packets 1 erx1 (192.168.1.1) 0.575 ms 0.569 ms 0.654 ms 2 * * * 3 * * * 4 31.55.186.184 (31.55.186.184) 8.945 ms 8.874 ms 8.873 ms 5 81.139.57.10 (81.139.57.10) 10.002 ms 11.118 ms 12.109 ms 6 195.99.127.98 (195.99.127.98) 12.099 ms core4-hu0-6-0-1.faraday.ukcore.bt.net (195.99.127.200) 8.511 ms core3-hu0-8-0-5.faraday.ukcore.bt.net (195.99.127.40) 13.158 ms 7 host213-121-193-187.ukcore.bt.net (213.121.193.187) 13.124 ms peer1-xe-11-0-0.faraday.ukcore.bt.net (213.121.193.169) 10.743 ms 9.200 ms 8 t2c4-et-8-1-0-0.uk-lon1.eu.bt.net (166.49.211.248) 8.184 ms t2c4-et-3-3-0-0.uk-lon1.eu.bt.net (166.49.211.246) 9.841 ms t2c4-et-8-1-0-0.uk-lon1.eu.bt.net (166.49.211.248) 10.612 ms 9 ix-ae-33-0.tcore2.LDN-London.as6453.net (80.231.20.1) 9.491 ms 10.461 ms 9.396 ms 10 if-ae-15-2.tcore2.L78-London.as6453.net (80.231.131.117) 18.767 ms 17.503 ms 15.703 ms 11 if-ae-14-2.tcore2.AV2-Amsterdam.as6453.net (80.231.131.161) 14.784 ms 15.277 ms 15.477 ms 12 if-ae-2-2.tcore1.AV2-Amsterdam.as6453.net (195.219.194.5) 17.503 ms 18.864 ms 17.968 ms 13 195.219.194.2 (195.219.194.2) 15.644 ms 14.491 ms 14.704 ms 14 * * * 15 [snip] 30 * * * smf22@lampu:~$ sudo traceroute -T 160.153.162.130 traceroute to 160.153.162.130 (160.153.162.130), 30 hops max, 60 byte packets 1 erx1 (192.168.1.1) 0.540 ms 0.538 ms 0.529 ms 2 * * * 3 * * * 4 31.55.186.184 (31.55.186.184) 9.383 ms 9.433 ms 9.326 ms 5 195.99.127.90 (195.99.127.90) 9.421 ms core3-hu0-16-0-3.faraday.ukcore.bt.net (195.99.127.198) 9.308 ms 195.99.127.98 (195.99.127.98) 9.308 ms 6 peer1-xe0-0-2.faraday.ukcore.bt.net (213.121.193.185) 10.410 ms host213-121-193-187.ukcore.bt.net (213.121.193.187) 9.738 ms 9.721 ms 7 t2c4-et-3-3-0-0.uk-lon1.eu.bt.net (166.49.211.246) 9.007 ms t2c4-et-7-3-0-0.uk-lon1.eu.bt.net (166.49.211.234) 8.117 ms t2c4-et-3-3-0-0.uk-lon1.eu.bt.net (166.49.211.246) 8.658 ms 8 ix-ae-33-0.tcore2.LDN-London.as6453.net (80.231.20.1) 8.084 ms 8.624 ms 8.030 ms 9 if-ae-15-2.tcore2.L78-London.as6453.net (80.231.131.117) 16.496 ms 16.210 ms 16.005 ms 10 if-ae-14-2.tcore2.AV2-Amsterdam.as6453.net (80.231.131.161) 14.792 ms 15.176 ms 14.770 ms 11 if-ae-2-2.tcore1.AV2-Amsterdam.as6453.net (195.219.194.5) 15.490 ms 16.141 ms 16.130 ms 12 195.219.194.2 (195.219.194.2) 14.650 ms 14.945 ms 14.744 ms 13 * * * 14 [snip] 30 * * *
As I'd mentioned previously I suspect this is a routing issue i.e., no return path, rather than a firewall.
The problem is beyond the point of BT's administrative control so there's little that can be done via this forum. I'd suggest contacting GoDaddy and show them that users on BT and VM are not able to connect and have them investigate.
Hi groppo91 - coincidentally I have a domain on that (shared) hosting IP from GoDaddy, and am experiencing the same issues that you are (since some point on Sunday 1st October).
Have bounced between GoDaddy and BT so far - but helpful to know that the issue is more widespread.
https://pulse.turbobytes.com might be helpful - provides traceroutes from a number of global endpoints - and the results indicate that our hosting IP is unavailable from 24/66 of these.
@tvol wrote:Hi groppo91 - coincidentally I have a domain on that (shared) hosting IP from GoDaddy, and am experiencing the same issues that you are (since some point on Sunday 1st October).
@tvol. Useful site.... thanks for posting that. With those results I don't see how GoDaddy can try bouncing you back to the ISP. I see failures from Brazil, Canada, Czech Republic, Germany, Denmark, Ireland.... and so the list goes on. Definitely not a BT problem
Worth noting that GoDaddy claim that tools such as pulse are 'not reliable' as anti-DDOS measures may kick in - not sure I'm completely convinced by that argument...
It does seem rather strange. 160.153.162.129 and 160.153.162.131 get the result in the image. The cpanel link works fine. While 160.153.162.130 returns this:
The server at 160.153.162.130 is taking too long to respond.
So, it would seem to suggest it's a godaddy problem.
