Message 1 of 5
Issues with signal w/ HD channels on Sky
Hi
There seems to be an issue for some people, including myself, with the BT Sport+ESPN HD channels on Sky. The signal can be either non-existent or poor, leading to artifacting/picture distortion.
See:
http://helpforum.sky.com/t5/Sky-HD-Picture-Sound/Choppy-no-signal-on-w-BT-ESPN-HD-channels/m-p/12437...
http://helpforum.sky.com/t5/Sky-HD-Picture-Sound/Picture-breaking-up-on-BT-Sports-and-ESPN/td-p/1243...
http://helpforum.sky.com/t5/Watching-Sky-Questions/Bt-sport-hd-pixilated/qaq-p/1244022
https://twitter.com/lloydjenks69/status/364665120342806528
https://twitter.com/LJReed8/status/363688628511182848
No doubt there are others as well.
We have all been told by Sky that it is a BT issue and the fact that it is *only* BT/ESPN HD which are having problems seems to point towards that too. The standard def ones work fine so in theory there might be a broadcasting issue on BT's end w/ the HD channels.
I and others have contacted BT who have tried 'refreshing' and other measures but it doesn't seem like any solution has consistently worked.
Obviously we are a minority but will BT be looking into this any further at all?
4 REPLIES 4
Distinguished Expert
Message 2 of 5
Re: Issues with signal w/ HD channels on Sky
Those problems are usually caused by the broadcaster not paying for sufficient bandwidth, i.e. BT are being a bit cheap.
To say thanks for a helpful answer, please click the white star
Recognised Expert
Message 3 of 5
Hmmm - wonder if it's possible for Sky to degrade their hardwares ability to receive certain channels?
Message 4 of 5
No, but it could be something like dish orientation. Some channels are affected more than others by dishes being out-of-alignment.
Message 5 of 5
Well atm I've booked in an engineer visit from Sky.
Hopefully that fixes it though I would think there is still some sort of issue on BT's end regardless if engineers are needed for multiple people to fix something that was a non-issue before BT started broadcasting their channels+took over ESPN!
