leftblank
Message 1 of 2
It's 2017 ... so is BT Mobile offering Visual Voicemail yet?
Yes, there are other messages/threads which state that BT Mobile doesn't support Visual Voicemail, but they're from 2014, 2015, 2016. BT is using the EE network, and EE supports Visual Voicemail, so I don't really understand why BT would not offer it too ...
Could somebody from BT please give the definitive 2017 answer: if I sign up to one of the otherwise attractive BT mobile packages, will Visual Voicemail be available?
[ Yes, I've used HulloMail ... I want proper Visual Voicemail, so I will stay with EE if BT isn't able to support it.]
1 REPLY 1
Seamaster
Message 2 of 2
Re: It's 2017 ... so is BT Mobile offering Visual Voicemail yet?
Seems pretty obvious. BT Mobile is a lot cheaper than EE. They have differentiated offerings as a result.
