Guru
Message 11 of 15
Re: Just BT Infinity not possible?
Its down to BT and what packages they want to offer.
I remember having separate contracts and separate accounts for each of the different products.
Today however, BT wish to "bundle" phone, broadband and TV (and probably mobile in the future), as they believe they can offer these cheaper and benefit the customer. They also keep the customer as they are less likely to change all their services.
All the products are sold as packages on the website. I would suggest to call the Customer Options team 0800 800 030 and ask them if they can give you what you want, just Infinity on its own.
Stew
Distinguished Guru
Distinguished Guru
Message 12 of 15
It's worth trying as Stew suggests, but he's right about the packages ethos and there's no guarantee. We live in a time of mass production, take it or leave it, one size fits all, computer says No, and tailor-made products don't interest big suppliers. My real name is Mr Blobby, but can I get a major car manufacturer to supply me with a vehicle kitted out in pink with yellow polka dots? No chance.
Message 13 of 15
Unfortunately there aren't many companies that allow broadband only contracts now however you may like to check P... N.. since they do if you have no joy from BT
Message 14 of 15
Thanks, Stew, for giving an actual practical suggestion. I'll try that, but it does seem a bit ridiculous that a customer simply wanting to get a particular service, instead of being forced into paying for several, is something that needs to be specially arranged.
Guru
Message 15 of 15
Good luck, hope you will get what you want.
