Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
I just received my HH3 but there is no modem including. Does the BT engineer brings the modem with him on installation day?
Solved! Go to Solution.
Yes!
Thanks mate for quick reply.
One more question will i be able to use Asus RT-N56U Black Diamond Dual-Band Wireless-N Gigabit Router with BT modem?
@Inam wrote:One more question will i be able to use Asus RT-N56U Black Diamond Dual-Band Wireless-N Gigabit Router with BT modem?
Yes. I'm using that very same router and it works beautifully!! (it looks good too).
Just set the WAN Connection Type to "PPPoE".
I used "bthomehub@btbroadband.com" as the username and a space character for the password and it connected straight away.
I replaced the HH3 about a month after I had Infinity installed late last year.
I've never had a problem with the router needing to be re-booted and it stays connected for weeks/months at a time. The last time it was reset was when we had a power cut!
Hope this helps.
