Inam
Message 1 of 6
Just received HH3 but no modem
I just received my HH3  but there is no modem including. Does the BT engineer brings the modem with him on installation day?
5 REPLIES 5
plymchris
Message 2 of 6
Re: Just received HH3 but no modem
Yes!
Inam
Message 3 of 6
Thanks mate for quick reply.
Inam
Message 4 of 6
One more question will i be able to use Asus RT-N56U Black Diamond Dual-Band Wireless-N Gigabit Router with BT modem?
astar27
Expert
Message 5 of 6
as long as it supports PPOE then yes. you'll need to set it up with the username bthomehub@btbroadband.com with no password (or if your router doesn't let you use no password, type in anything it will still connect
SuperFlyGuy
Message 6 of 6
Yes.  I'm using that very same router and it works beautifully!!  (it looks good too).
Just set the WAN Connection Type to "PPPoE".
I used "bthomehub@btbroadband.com" as the username and a space character for the password and it connected straight away.
I replaced the HH3 about a month after I had Infinity installed late last year.
I've never had a problem with the router needing to be re-booted and it stays connected for weeks/months at a time.  The last time it was reset was when we had a power cut!
Hope this helps.
