swimmer
Message 1 of 13
Just signed up with BT Broadband Option 1 but have terrible connection speed
HI,
I have just moved into my property which had Virgin already there but being a long term customer of BT I signed up to BT Broadband, I was told the expected speeds for my address would be 2 to 6.5MB estimated at an average of 3.5MB.
Because of this I chose BT Broadband Option 1 but so far the speeds have been terrible.
Below are the results of the speed tests I have done most after 11.00pm at night.
15/12/11   Download 0.60Mbps   Upload 0.36Mbps
17/12/11   Download 0.39Mbps   Upload 0.36Mbps
19/12/11   Download 0.42Mbps   Upload 0.36Mbps
20/12/11   Dowmload 0.39Mbps   Upload 0.36Mbps
BT Engineer installed the master (only socket) and the cable from the Telegraph pole to my property was replaced, my router is connected to this socket with the filter and telephone too.
The previous property was giving me over 4Mbps to just downloading a single is taking ages now.
I have tried the quiet test with a corded phone and all seemed fine to me plus at the moment I only have the one telephone socket.
Any constructive advise would be appreciated.
12 REPLIES 12
Message 2 of 13
Re: Just signed up with BT Broadband Option 1 but have terrible connection speed
you need to provide the adslstats from your hub and also run btspeedtester and post the results
Message 3 of 13
Hi Welcome to the forums
If you post the full stats from your router
For homehub – type 192.168.1.254 into your browser
Navigate to ADSL Settings or use the A-Z at the top right of the home page and scroll down to ADSL Settings and click on it
Click on More Details and then post the full results.
also post the full results from http://speedtester.bt.com/
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
also you could try the hints given by poster RogerB in this link they may help http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
Then someone here may be able to help and offer more advice.
This is a customer to customer self help forum the only BT presence here are the forum moderators
swimmer
Message 4 of 13
Thank you all, when I return from work I shall post my results tonight.
swimmer
Message 5 of 13
Hi, Here are the results from my hub, every time I try and do the BT Speed test it fails ad says Internet explorer can not display the web page even though my laptop is connected to the router by cable as per BT instructions, if i choose the Beta speed check option that works and came up with a download figure of 0.2.
ADSL Line Status Connection information
<script type="text/javascript"></script> Line state:
<script type="text/javascript"></script> Connected
<script type="text/javascript"></script> Connection time:
<script type="text/javascript"></script> 0 day, 00:24:07
Downstream:
<script type="text/javascript"></script> 768 Kbps
Upstream:
<script type="text/javascript"></script> 448 Kbps
<script type="text/javascript"></script>   ADSL settings
VPI/VCI:
<script type="text/javascript"></script> 0/38
Type:
<script type="text/javascript"></script> PPPoA
Modulation:
<script type="text/javascript"></script> G.992.1 Annex A
<script type="text/javascript"></script> Latency type:
<script type="text/javascript"></script> Interleaved
<script type="text/javascript"></script> Noise margin (Down/Up):
<script type="text/javascript"></script> 20.4 dB / 15.0 dB
<script type="text/javascript"></script> Line attenuation (Down/Up):
<script type="text/javascript"></script> 55.0 dB / 31.5 dB
<script type="text/javascript"></script> Output power (Down/Up):
<script type="text/javascript"></script> 14.9 dBm / 12.6 dBm
FEC Events (Down/Up):
<script type="text/javascript"></script> 123879 / 93
CRC Events (Down/Up):
<script type="text/javascript"></script> 6168 / 92
Loss of Framing (Local/Remote):
<script type="text/javascript"></script> 0 / 0
Loss of Signal (Local/Remote):
Loss of Power (Local/Remote):
Loss of Link (Remote):
HEC Errors (Down/Up):
<script type="text/javascript"></script> 6128 / 97
Error Seconds (Local/Remote):
Internet Explorer cannot display the webpage
 What you can try:
Diagnose Connection Problems
More information
Message 6 of 13
you could try another web browser and see if that solves any problems
Message 7 of 13
your connection time is only 24min is that due to a manual reset or the router dropping connection.  have you been having problems with the router dropping connection as your noise margin is higher than normal 6
swimmer
Message 8 of 13
I had to reset the router as the broadband light was flashing. I managed to get the speed test to work using Firefox and these are the poor results
FAQ
<script type="text/javascript"></script> Test1 comprises of two tests
1. Best Effort Test:
-provides background information.
Download  Speed
35 Kbps
0 Kbps
1000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 35 Kbps
 For your connection, the acceptable range of speeds
is 400-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :768 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 676 Kbps
2. Upstream Test: -provides background information.
Upload Speed
366 Kbps
0 Kbps
448 Kbps
>Upload speedachieved during the test was - 366 Kbps
 Upstream Rate IP profile on your line is - 448 Kbps
gouledw
Recognised Expert
Message 9 of 13
ADSL Line Status
Downstream:
768 Kbps
Upstream:
448 Kbps
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Interleaved
20.4 dB / 15.0 dB
55.0 dB / 31.5 dB
14.9 dBm / 12.6 dBm
123879 / 93
6168 / 92
0 / 0
0 / 0
0 / 0
0
6128 / 97
0 / 0
Sorry was annoying me so I correctly formatted it.
swimmer
Message 10 of 13
Thank you
Tags (1)
